Old 02-26-2016, 06:15 PM   #1
LPTC's Avatar
Chassis: Thomas
Engine: 5 speed Manual
Rated Cap: 35
Problems starting my 5.9 cummins
Just bought a new 5.9 l cummins freightliner. Batteries were weak from the get go so I sprung for two brand new 31D's. Started up when I installed real easy.
Drove it around that day, then had it sit over night. Next morning (day 2) took a little time but it eventually started.
Now this afternoon (day 3) electrical comes on, glow plugs work, but all I get is click, doesn't chug or anything. Cleaned all the terminals and tried again, but still same thing.
Voltometer is reading 12.4 on these brand new batteries....
My question is, could this be an alternator issue, or wiring problem?
Not sure what my next troubleshoot move is, or maybe it's the starter.
Any advice or tricks of the trade would be greatly appreciated.
“If you’re going to be crazy, you have to get paid for it or else you’re going to be locked up.”
-Hunter S. Thompson
LPTC is offline   Reply With Quote
Old 02-26-2016, 06:31 PM   #2
See if you can get it started with a jump. if you got 12V at the battery then it is likely the alternator. i would check the charge circuit wiring and see if anything is loose or corroded first though.
keiffith is offline   Reply With Quote
Old 02-26-2016, 07:26 PM   #3
Robin97396's Avatar
Yeah, what keiffith said. Always start with the easiest means of elimination.
Those new batteries should have lasted for a while, even if the alternator is bad. It sounds like a short might be draining your batteries. I've bought a number of vehicles at auction that had electrical issues and little else wrong with them.
Old 02-26-2016, 07:33 PM   #4
opus's Avatar
Chassis: All-American R/E
Bad ground.
Old 02-26-2016, 10:02 PM   #5
LPTC's Avatar
Chassis: Thomas
Rated Cap: 35
I am thinking it is a wiring issue as it was clicking when running and the voltage meter would drop.
If it is a wiring/grounding issue, would replacing the terminals do the trick?
Also, when disconnecting batteries, is the rule to undo the negative first?
-Hunter S. Thompson
Old 02-26-2016, 10:03 PM   #6
LPTC's Avatar
Chassis: Thomas
Rated Cap: 35
what is the charge circuit wiring?
-Hunter S. Thompson
Old 02-26-2016, 10:11 PM   #7
Chassis: International 1753
Engine: 6.9 International
What's the voltmeter read on the batteries when you try and start it?
Old 02-26-2016, 10:35 PM   #8
LPTC's Avatar
Chassis: Thomas
Rated Cap: 35
voltometer was reading 12.54
-Hunter S. Thompson
Old 02-26-2016, 10:51 PM   #9
The wiring that ties in your alternator to your batteries
Old 02-27-2016, 08:48 AM   #10
If you have more than 12 volts at the battery then you should have enough to get things going.
Since you obviously don't have enough juice to get things started then my first suggestion is you have a bad connection, most likely with one or more of the battery connections.
I really like the Group 31 batteries with stud connections rather than post connections. Not only do they not get as crusty with crud over time but they are a lot easier to clean than lead posts and soft metal terminal ends.
After cleaning all of the battery connections so that you have a shiny surface on the posts and on the inside of the terminal ends make sure the terminal ends are tight and can't move. Even a little wiggle can cause enough of a voltage drop to make things not work.
If after the cleaning and tightening doesn't work go to the other ends of the battery cables and make sure all of those connections are good and tight.
Our church bus had brand new batteries and a week later it wasn't starting. Come to find out the negative end that connected to the frame of the bus had worked itself loose.
It helps make a good ground if the ground lead has a nice shiny surface with which to mate. I have seen where frame rails had so much paint on them the ground had a hard time making a good connection just through the bolt.
If after all of the cleaning and tightening you are still having problems I would get an inductive ammeter on the battery cable while someone hits the starter. If you peg out the ammeter it could mean you have a bad starter. It could also mean you have bad cabling between the battery and the starter. I have seen cables that looked good but when cut open they were green instead of shiny copper.
If after cleaning, tightening, checking for bad cabling, and a bad starter and things still don't want to start you need to check the ignition switch and ignition switch circuit. A bad solenoid can make things hard to start.
Let us know how things work out for you.
alternator, batteries, starter, starting issues, wiring problems
