Old 06-02-2019, 09:28 PM   #1
Rear axle wheel seal 1999 bluebird tc2000 2510-2700 part number?
Hey guys, just joined the skoolie family this weekend, driving the bus back it blew a wheel seal on the rear passenger side wheel blew out sometime around the last hour of our 10 hour journey. My dad works on heavy duty diesel trucks and can use the shop after hours for us to fix it. Just having trouble locating the right part and can't find much online. Gonna try calling bluebird tomorrow but was wondering if you guys can point me in the right direction.
Rear axle number 1994110
Vin 1baaccsh6xF085430
If not, can I call bluebird directly to find out or should I call a dealer? Closest one that works on um seems to be in MA.
Lotheren is offline   Reply With Quote
Old 06-03-2019, 12:02 AM   #2
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
It will probly be easiest to find your axle manufacture and model. Then it's easy for a truck part supplier to look it up. The should be a tag with this info on a bolt on the differential.
Ted
Old 06-03-2019, 06:02 AM   #3
I'll go under and take a look.
Old 06-03-2019, 09:14 AM   #4
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
If the dealer is no longer able to get a new seal, you might have to take it apart and physically examine the faulty seal.
A micrometer measurement of the OD and ID of the seal will get you pointed in the right direction, provided no other markings are found on the seal.
NAPA auto parts or any power transmission supply dealer can provide a new seal.
Old 06-03-2019, 09:55 AM   #5
A bluebird dealer was able to find the right number for me and cross referenced with a Chicago raw hide part. Also got a fresh gasket. I dont think the hub has been taken off in its 200k miles as I've been beating on it with a sledge hammer and it still wont budge. Started dripping a little but I've run out of time to get it off.
Old 06-03-2019, 02:03 PM   #6
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
Bro you donít have to go all HAAM on the hub. Being a mechanic isnít all about beating the **** out of things with a BFH haha. Step back, examine your work area. You might find you missed something. Post some pics so we can see it all!
WARGEAR is offline   Reply With Quote
Old 06-03-2019, 03:41 PM   #7
Engine: TE 444
Rated Cap: 12
First you pull the axle shaft, then you undo the big nuts inside that holds the hub and bearings in place, then the outer bearing will come out and the hub will come off with the inner bearing and seal retained
Old 06-03-2019, 03:48 PM   #8
HazMatt's Avatar
Chassis: IH 3800, 8 window
BFH, I got. But what is HAAM?
Is that in any way related to bacon?
mmmm, baaaaaay-con... 🤤
Old 06-03-2019, 08:50 PM   #9
WARGEAR's Avatar
HardAsAMotherfucker=HAAM but yes bacon is delicious haha
-Nick
Old 06-03-2019, 08:57 PM   #10
HazMatt's Avatar
Roger that, & thankya for the clarification!
See, HAAMF I mighta figured out for myself, coz I'm not used to considering Mo Fo as a, pardon the grammatical pun, conjugated word...
