09-01-2018, 09:14 PM
Coachwork: International - AmTran
Engine: DTA 360
Rated Cap: 25,500 lbs
Rear Diff ratio?
Im considering lowering the rear differential ratio on my Comfort bus.
I have a DTA360 attached to a ATA545 with 10r22.5 tires. Tire circumference is about 42 inches. Trans in 4th is a 1 to 1 ratio. Id like a rear diff ratio to allow 65MPH at about 2700-2800 rpm. Can somebody help figure a good ratio? Vander Haags has Spicer N175 diffs in a variety of ratios for $650 each. I figure this would be a better investment than a MT643 which has the same 4th gear ratio. Possibly get me better mileage since I dont haul anything and drive mostly 90% or better highway miles.
www.vanderhaags.com/detailview.php?part=24648952
09-01-2018, 10:16 PM
Plug your numbers into the bottom calculator...then you can play with any of them and see the difference.
Engine RPM Calculator
09-02-2018, 12:45 AM
Engine: DTA 360
super easy, thanks a bunch
That was super easy. Thank You for posting that link.
I'm going to try and get a 4.44 or 4.10 ratio. good options and keeps the engine in its power band. Id rather see 2100 RPM at 60MPH than 2900RPM
Now to make the purchase and swap em out.
09-02-2018, 08:59 AM
Roger that. Many benefits to be had by keeping a diesel in or near its' "sweet spot".
And most people are surprised by the differences even small adjustments can make. Sometimes you can achieve what you want with a minor change in tire size instead of a big $$$ re-gearing.
That calculator can be fun to play with. Glad to hear it helped.
09-16-2018, 11:41 AM
Chassis: Blue Bird
Engine: ISC 250
Rated Cap: 31
trans lockup?
Stop me if I'm wrong, but don't you have a transmission without lockup?
Wouldn't you benefit more from the transmission swap?
http://www.skoolie.net/forums/f33/mt...nay-24142.html
I just recently saw somewhere that someone had purchased Allison's back stock of older transmissions, including MT643s which they were selling for around $650.
09-16-2018, 02:11 PM
Engine: DTA 360
Yes, I have a AT545 in the bus. I have found a remanufactured MT643 to purchase. I have not found any of those surplus for $650. If anybody has a link to those, I'd gladly check em out.
09-16-2018, 03:44 PM
here is where I got mine.. im in the middle of the swap on a DTA-360 as we speak..
https://www.lkqheavytruck.com/part-d...ON&model=MT643
09-16-2018, 04:56 PM
Engine: DTA 360
Nice. It says it's been renewed/remanufactured by Allison. I'm going to call on Monday to find out. If it's accurate and shipping is acceptable. I may get that instead.
09-16-2018, 06:55 PM
Chassis: Blue Bird
Engine: ISC 250
Rated Cap: 31
Yep I just found that in my web history
cadillackid beat me to it
We've got a B300R so my big goal is to get sixth unlocked... rear axle ratio is 5.38. Sadly it's in a Blue Bird, so I would realistically need to get a TCM for that.
09-18-2018, 01:43 AM
Engine: DTA 360
I called and the price is good as well as the shipping. Sure beats $2,000 for the same thing. All that is left on my upgrade list is a DT466. Well that air disc brakes, insulation, new floor, better seats, ect.
09-18-2018, 09:51 AM
Chassis: Blue Bird
Engine: ISC 250
Rated Cap: 31
Yes, at that price, it seems too good to pass up.
09-18-2018, 01:10 PM
when I got mine i was told that these were ordered by Navistar to be remanufactured and they were stock for them in their warehouse.. used when a vehicle would come into the dealership needing a reman transmission... Navistar recently deleted them from their parts book and no longer wanted to stock them.. each one has a Navistar part number on it and was remanufactured by a navistar certified company..
LKQ bought up all the stock on them and has (had) a Bunch of them.. for those who have an AT545 and want an easy swap out if you thinkl your AT545 is dying.. they also had plenty of 545's for "$545"..
--Notes--
the included torque converter is designed for a DT466 engine. and the RPM shiftpoints are set at 2600 RPM.. you can use these really on any diesel engine with similar torque and RPM range as the DT466.. (DT-466E)..
these will NOT have the correct stall speed and RPM ranges for the high revving 9 Litre Diesel or any of the gasoline engines...
installing a 643 on a T-444E will require a Cross member.
the torque converter stall cannot be adjusted, however just like on a 545 there are in-pan hard stop shift adjustment wheels that can be tuned if you so choose.
on a mechanical DT360/466 you can fine tune your shift points by simply adjusting your modulator cable.. on a DT-466E you are stuck with an on/off electric modulator which is nothing more than a kickdown...
at WOT it should shift at 2600 or thereabouts regardless.. and even though a DTA360 can be run at 3000 RPM.. you dont want to shift it there.. its peak HP is at 2300. a DT466 also peaks at 2300 for HP.. so a buried in the floor shift of 2600. places you back into a solid portion of your powerband in the next gear...
10-06-2018, 05:32 PM
Engine: DTA 360
cadillackid Hows it going with the at545 to mt643 swap? I know the spacer has to come out and using shorter bolts for the flywheel/flexplate but is there enough room for the bolts/nuts to secure the flex plate to the torque converter? OR does it still need a spacer but much thinner?
