Old 09-08-2016, 01:51 AM   #1
Rear lights not workinf
Hey all thanks for helping.
I have a Thomas build cutaway with a 2002 ford e450 7.3 L. Recently I have an issue where the brake lights, rear interior some lights, rear emergency buzzer, and ALL overhead controls (bus lights, stop sign, AC compressor, etc) do not work. They were working very dimly before I turned switches off and on, and now they don't work at all. I'm thinking fuse or a common ground gor jacked up. Any thoughts people?
Heeelp
decker1 is offline   Reply With Quote
Old 09-08-2016, 02:34 AM   #2
Chassis: IH
I think I'd be checking some electrical grounds.
Old 09-08-2016, 03:22 AM   #3
Which grounds are you thinking? Much appreciated
Old 09-08-2016, 03:54 AM   #4
Come to think of it, a lot of the lights were/still are on that shouldn't be on. Such as the domelight, and fuse box light. Maybe a common ground is flipping anything that touches ground
Old 09-08-2016, 09:52 AM   #5
Carytowncat's Avatar
With dim control and some lights just heing on with the switch off,
that sounds like a light control modue, if that bus even has one of those.
Good luck!
Old 09-08-2016, 12:41 PM   #6
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
When we first got our bus it was like that because they ripped off the stop arm at the bus garage and left the wiring a mess. There was also some kind of odd flasher box that was wired in funky and made the horn go off if the door was opened. We dismantled that box and just generally cleaned up the wires and made sure they were going to the right place. Now everything works fine. I do remember one wire that went to the stop arm that we had to bundle up out of the way. Maybe yours is touching metal somewhere.
My build thread:http://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
onenationundergoat is offline   Reply With Quote
Old 09-08-2016, 12:44 PM   #7
Come to think of it, I too accidentaly ripped off the stop sign . It's still there if just dangles. I forgot how I did that. I will check this out. Thanks!!!
Old 09-08-2016, 10:25 PM   #8
Well I pulled the stop sign off. Still no dice . What is that livht box you are taking about? I am
Not sure what this is. Is it part of the stop sign?
Old 09-09-2016, 12:32 AM   #9
Chassis: Thomas
Rated Cap: 60
They had installed some sort of black plastic box with labels regarding flashers and buzzers. Aftermarket obviously.
Have you ever taken off your tail light lenses? once we smushed the wiring to the tail light under the edge of the red lense and it wouldn't work anymore. but i don't think that would affect your whole system.
Old 09-09-2016, 03:11 PM   #10
Oh gotcha . No I have not. I am starting to think that the stop sign blue a top level fuse. The sign is removed but what fuse could control so many electronics ?(driver fan, bus lights, rear dome light, etc). Also the front door activated dome light will still not turn off.
