Old 12-04-2014, 11:28 PM   #1
Coachwork: Goshen
Chassis: frieghtliner mt55
Engine: cummins isb
Rated Cap: 25
Rear suspension noise (jingle on bumps)
I have a leaf spring rear suspension on my bus - it's a 96 frieghtliner mt55 chassis with a Goshen Oshkosh converted to a tour vehicle for my band omingnome. My knowledge is limited as to the names of specific parts of the suspension system so I can provide some pictures with descriptions
In the first two pictures there's is a large washer in between the large arm of the suspension on the left and what appears to be a bracket that attaches to the brake. That is causing a noticeable jingling sound from below. I thought it was just on the right side, but when I felt the washer on both sides of the bus, both washers were loose to the touch and would move about 3/8s of an inch freely, side to side.
The third and fourth picture is what may or may not be another potential issue related to the loose washer and that is what appears to be a giant black bushing that is crooked sitting attached to the large arm of the suspension.
Any thoughts as to what these issues may be?
Thank you,
Omingnome from the road somewhere is Mississippi
Omingnome is offline   Reply With Quote
Old 12-07-2014, 06:03 PM   #2
Re: Rear suspension noise (jingle on bumps)
No pictures of thing-a-magingees
Welcome to skoolie
Old 12-08-2014, 08:17 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
No pictures here either, sounds like bushings in spring eye need replaced.
Flat face FE bus noise rlohrey Skoolie Conversion Projects 10 10-19-2012 10:25 PM
Engine noise on a flat nose jugganaut Conversion General Discussions 15 10-04-2010 10:05 PM
Screaming Noise of Death: air brake issue? BUSBOZO Conversion General Discussions 4 03-22-2010 09:24 PM
Power steering noise captainkf Conversion General Discussions 3 09-22-2007 12:50 AM
Bus Engine Noise Jeff in AK Conversion General Discussions 8 07-29-2004 03:09 PM
