Old 07-09-2012, 08:24 PM   #1
Engine: Cummins
Safe Arc Welding on A Bus
I have a 2003 TC 2000 and want to fabricate a hitch for it, but want to know what to do to make it safe to weld and not blow the electronics. The 2003 is the first year with a computer on engin. Any help would be geatly appreciated.
Jeff
jeff is offline   Reply With Quote
Old 07-10-2012, 12:23 AM   #2
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: Safe Arc Welding on A Bus
IIRC, I've read that you can remove the battery cables, and connect them together. Some also disconnect their elctronics. Others say just make a good clamp connection of your welder lead as close as possible to the work. You just want to prevent welder current from going through the electronic stuff.
Old 07-10-2012, 02:27 AM   #3
esp for the computer vehicles, always disconnect the battery. and to be safer clamp the ground close to where you are welding instead of at the other end of the vehicle.
esp when running a mig.
i normally just weld if using the sureweld stick welder and not disconnect the battery, but have had elect problems after using both migs.
Welding? Zephod_beeblebrox2 Conversion General Discussions 15 02-01-2015 09:39 AM
So, about that welding near the gas tank... Ob1 Conversion General Discussions 1 05-06-2011 02:58 PM
Gun safe in a bus madpsalmer Conversion General Discussions 5 02-10-2011 07:14 AM
Welding Advice Hvbuzz Conversion General Discussions 2 12-02-2010 01:53 AM
Installing Tanks without Welding Steve Plumbing, Water and Waste 2 06-15-2010 04:06 PM
