Old 01-28-2010, 10:06 AM   #1
Engine: DTA360
Rated Cap: 70
School bus construction
Hello I just acquired a Carpenter International with DT360 5 speed. I am into transit coaches and know how they are built. But how is the body on a typical school bus built? Is it on a tubular frame like a transit or are they built different? I mean in the walls and roof I know they have an I beam frame kinda like my Gillig. Thanks scoob
scoobydoo6v92 is offline   Reply With Quote
Old 01-31-2010, 12:05 PM   #2
Engine: DTA360
Rated Cap: 70
Re: School bus construction
I asked this question three days ago. Doesn't anyone on here know? Or can someone direct me to a forum that does? Thanks
Old 01-31-2010, 12:44 PM   #3
I don't know if this will answer your question or not.
I have 2 thomas built busses, a rear engine diesel pusher, and a front engine gasser conventional nose. Both have a medium duty truck style "ladder" frame. Two major frame rails, with lots of cross members. The frame rails are C channels.
Upon these frame rails, the floor of the body appears to be constructed of a lot of bent steel sections that run perpendicular to the frame rails. These sections are also C shaped, with an approx. 1" lip on each end of the C, and the back of the C being the surface of the floor.
I haven't gotten far enough into the walls of either bus to see how the walls and ceiling are constructed. However, from the conversion threads I've read on here, it appears that there are ribs running from the ends of the floor sections up and over the top in a hoop configuration and back down to the floor on the other side. These hoops run up between the windows. I'm not sure of the exact configuration though.
There is an inner and an outer skin for these walls, that helps form a hollow box, usually filled with insulation. The skin is typically steel, and I've seen a variety of attachment methods, from riveting to torx screws to standard phillips head screws.
Down the outside of the sides there is a "rub rail". This performs 2 functions, one being to help protect the skin in the event the driver scrapes something, and the other is to add extra rigidity to the sides. As a side effect, these collect grime and water, ruining your attempts to paint the vehicle.
Upon the roof of my 2 busses, there's also an area about 2' or 3' wide, that has ribs on either side. These like to hold water as well, and I think adds some strength in the case of a rollover event.
I hope this information is helpful in some way,
jim
baadpuppy is offline   Reply With Quote
Old 01-31-2010, 10:20 PM   #4
Pictures? You might try looking through the gallery, alot of nice pictures in there. Probably find what your looking for in short order.
Old 02-03-2010, 05:12 PM   #5
thesaltydog24's Avatar
here are some pics I found in the gallery. (click on full size for a better view)
here you can see the side view without the skin of the bus.
http://www.skoolie.net/gallery2/v/Skooli ... 1.jpg.html
I think he was doing a roof raise and wanted to re skin the whole bus and include storage bays underneath
http://www.skoolie.net/gallery2/v/Skooli ... 7.jpg.html
Chris
thesaltydog24 is offline   Reply With Quote
Old 02-05-2010, 09:47 AM   #6
Engine: DTA360
Rated Cap: 70
Thanks very much for your replies and pictures. I now understand how they are built. There isn't a tubular frame but a "C" channel type thing. Looks stout. Smitty I really enjoyed your website and the pictures of your Carpenter. I have the same bus. So now I know how my bus is put together. I need to fix the welds on my roof which this spring I will do. I would love to raise my roof so I can put in a hardwood floor.
Thanks Scoob
Old 02-09-2010, 03:14 PM   #7
Engine: DTA360
Rated Cap: 70
Yes I know my bus was made in Mitchell. You can tell by the rub rails if the rub rail is broken by the wheels like mine it wa made in Mitchell Also I noticed one weld over the door needs serious attention. IT is no big deal as I can weld thankfully. I would never use it for passengers if I were a transportation company. Unless it was repaired by a certified welder. Scoob.
Conversion/construction/building guidelines? tomas_maly Conversion General Discussions 4 07-26-2012 01:48 PM
Blue Bird construction video pipopak Skoolie Conversion Projects 5 06-17-2012 07:58 PM
Ceiling Construction Question chev49 Conversion General Discussions 0 03-20-2012 07:54 PM
75 Bluebird and 57 chevys under construction BusLiving Skoolie Conversion Projects 2 04-18-2005 03:50 PM
Cabinet and Interior Construction Ryan Grimm Conversion Tutorials and How-to's 3 03-30-2005 08:23 AM
