Old 04-08-2016, 02:28 PM   #41
Chassis: Blue Bird
Engine: ISC 8.3
Originally Posted by CaptSquid View Post
I don't have metal strips in the middle of my front doors. They're aluminum framed glass. The glass is uninterrupted from top to bottom.
There must be some arm fixed to the door frame a few inches away from the pivot point, right? Or maybe the pivot is an axle, and the operating arm is hidden behind a cover above the door.. My front doors (now deleted) sound similar to yours. One of the doors had a short arm attached to it, to which a regular rod end was bolted and the control rod ran off to somewhere else in the mechanism. I realized that if I could prevent that bolt from moving it would directly hold the one door leaf fixed closed and via the rod end and rod would also prevent the other leaf opening. I replaced the bolt with a section of threaded rod and a coupler nut, then positioned a piece of sheet metal with a hole drilled through just below where the coupler nut sat with the doors closed. I could thread a screw through that sheet into the coupler nut and it would prevent opening the front doors. My rear doors already had locks, so I'd secure the front from the inside then exit through the rear and lock that from the outside.
Old 04-08-2016, 03:13 PM   #42
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Originally Posted by Scooternj View Post
I prefer claymore mines, myself
But claymores are so noisy!
Old 04-08-2016, 04:27 PM   #43
Robin97396's Avatar
Yes, but it is followed by silence.
Old 04-08-2016, 04:57 PM   #44
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Lmao
Sent from my Nexus 6 using Tapatalk
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 04-08-2016, 06:17 PM   #45
Engine: Cat 3126e
Rated Cap: 28
Sweet I was just about to look for this info again.
Josiahdr is offline   Reply With Quote
Old 04-08-2016, 06:23 PM   #46
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
I'll take a look tonight.
Old 04-08-2016, 09:49 PM   #47
cheryl_ann44's Avatar
Chassis: International 3800 chassis
Engine: T444e
Back door
What are u using as steps for exiting rear of bus--I need ideas
cheryl_ann44 is offline   Reply With Quote
Old 04-09-2016, 12:51 AM   #48
Robin97396's Avatar
You can always cut a hole big enough for your foot in that big black bumper.
Old 04-09-2016, 05:50 PM   #49
Chassis: Blue Bird
Engine: ISC 8.3
Sorry... mine was used in transit service. It has a "rear" door on the side, just forward of the rear axle, like a city bus. With built-in steps. I didn't use the rear door much on the school bus I had before this one, so I never solved that problem.
Old 04-10-2016, 09:35 AM   #50
Chassis: International 1753
Engine: 6.9 International
I got this.
