Old 04-06-2009, 12:49 PM   #1
Lady Franklin's Avatar
Engine: 7.3 International Diesel
Semi Exhaust
A question for you HD mechanics and truck savvy people out there. ( that means you Paul and you too Elliot!) I have been thinking of re-routing the exhaust to a semi stack type system that would rise just behind the front fender. We hope to re-direct the fumes up and away from the ground so as to avoid such nuisances as cancer and other pesky illnesses. I even thought it would look pretty wild to have two stacks rise on either side then taper back onece it reaches the roof. But is it bad to turn the exhaust so abruptly? How does a semi trucks exhaust work? Of course this is just another flighty idea of mine, but hey why not dream right?
Lady Franklin is offline   Reply With Quote
Old 04-06-2009, 03:12 PM   #2
Re: Semi Exhaust
if you run the exhaust up the front, you will want to run a muffler to cut the noise down, get mandrel bent exhaust tube, u-turn the exhaust and bring it out where ever you want to.
if it was my bus, I'd do what elliot did and remove the muffler and run 4" exhaust straight out the back or maybe a side dump just in front of the rear tire on which ever side the exhaust runs on, or maybe the left side so that it is away from the camping side while you are getting situated and setup.
a truck parts supply can get 10' straight sticks and 90% mandrel bends in 4 & 5" diameters as well as various adapters and hangers, after your shopping trip it's just a matter of cut, fit & weld, all skills that you have already demonstrated.
Old 04-06-2009, 07:05 PM   #3
the_experience03's Avatar
Re: Semi Exhaust
I'd be worried about visibility. Find a chunk of 4" PVC and throw it up there just to see. I bet you won't be able to see your mirrors effectively and without them...well...you're running blind.
Old 04-08-2009, 11:33 AM   #4
Re: Semi Exhaust
Ya I had thought about running it up through a corner after I saw a transit bus with the set up. Then I started to think it through, having a penetration through the roof and trying to fire proof everything. I can see it turning into an issue down the road, literally. Perhaps if I had designed the bus from the start for this it would work but now it would mean cutting a corner out of the bedroom and too much trouble. All this and I would still have to convince my loving wife! I think if I can run the stacks infront of the mirror without blocking visibility then great if not I think its going out the port side! Thanks for the input.
Old 04-08-2009, 02:47 PM   #5
Re: Semi Exhaust
You also have to realize that when most transits and such run it up thru the body it is NOT in the passanger compartment. On most it is run up thru the engine bay. Exhaust and passangers are a bad combo.
On my semi exhaust there is a 90 deg bend right up behind the cab so I assume they are not a problem. Just to let you know I absolutly hate driving semis that have the stacks that come out right beside the sleeper. They are very hard to see around and although the sound is kinda cool at first after 500+ miles a day it gets rather annoying quickly.
letz4wheel is offline   Reply With Quote
Old 04-11-2009, 08:56 PM   #6
Re: Semi Exhaust
Point taken, will consider carefully.
Old 04-12-2009, 10:25 AM   #7
Re: Semi Exhaust
the turbo on a turbo diesel supplies all of the necessary backpressure, after the turbo minimal bp is best.
Old 04-12-2009, 09:46 PM   #8
Re: Semi Exhaust
I remembered a bus I was looking at that was for sale a while back. Here is a posting that has a photo of about what one would look like.
http://www.skoolie.net/forum/viewtopic.php?f=12&t=1290
Here is the photo from the posting:
Castro is offline   Reply With Quote
Old 04-21-2009, 11:45 PM   #9
Re: Semi Exhaust
Cheese wagon said,
Didn't realize this was a turbocharged application.....
It's not... Yet!
Exhaust and oil pan problems Seeria Mechanical and Drivetrains 3 08-10-2010 11:23 AM
Routing Exhaust... bus-ted Short-Bus Conversion Projects 3 06-27-2010 01:13 PM
Exhaust questions... jkindt Mechanical and Drivetrains 4 03-16-2010 09:43 PM
Windshield eyebrow for School Bus or Semi Abbott Conversion General Discussions 7 06-09-2008 09:07 PM
Need Semi-truck info. (9670 Int. 3406b cat.) bdavis441 Everything Else | General Skoolie Discussions 20 11-24-2007 01:15 PM
