Old 02-20-2010, 01:12 PM   #1
Joe Monstermaker's Avatar
Service life of MT643 Transmission
I'm still looking at busses... and I know this is an "it depends" kind of question, but generally speaking, how many miles is an MT643 good for between overhauls? One I'm looking at has bout 150k... another bus has 215k... is that "a lot" on an original unrebuilt bus trans?
Joe Monstermaker is offline   Reply With Quote
Old 02-20-2010, 08:12 PM   #2
frank-id's Avatar
Allison MT643 Transmission
The Allison name says it all. These trans are very long lasting if.... there is good oil cooler, a very large oil filter and occasionally the trans is checked by a pro shop. These units are very strong and can usually only be destroyed by lack of oil or cooked. A simple temp gage just for the unit is a very good investment for any longevity. The units are very adjustable for most applications. Frank
Old 02-22-2010, 05:10 PM   #3
Elliot Naess's Avatar
Engine: 5,9 Cummins
Re: Service life of MT643 Transmission
Well, now, Mr. Monstermaker -- if that is your real name....
Still thinking about a bus, eh....
First of all, make sure you get an MT6xx-series tranny, and not the AT5xx-series. (If you find a real beast of a bus, you might get an HT7xx-series.)
There is supposed to be a real Allison guru up there in your area. Power Shift Northwest in Woodinville. Fellow named Harry Mayer. Might ask him.
But I think it depends more on the individual specimen. As Frank said, Allisons are strong, but must be kept cool and clean.
You also want to make sure the modulator cable from the food feed pedal is adjusted correctly.
When you are shopping for a bus, I think all you can do is smell the fluid and drive the thing. Or pay for somebody like Harry to drop the pan and really inspect it properly.
Of course, look for a stick shift!
Elliot
Old 02-28-2010, 02:07 PM   #4
Yeah... that's my real name... Captain Mons... uh... I mean, Joe Monstermaker.
I happen to live in Woodinville, maybe I can track that guy down.
I know no one can tell me what shape a transmission is in over the 'net, I just wanted a general consensus about whether it's reasonable to expect an MT643 that appears to function properly, at 200k, would be likely to survive dragging a heavy object on a trailer behind a bus (8000 pounds or so) over a few mountain passes and into a desert in the middle of summer.
I drive big-trucks and I know 500k is reasonable for engines and manual transmissions to survive, but I've never had any experience with an automatic other than car/pickup stuff. And that hasn't been good experience!
P.S. I really need someone to tell me it's a bad idea and will immediately blow up, so as to discourage me from dragging home another big vehicle.
Old 02-28-2010, 02:38 PM   #5
Engine: 5,9 Cummins
Hmmm. Well, yes,
My dream is to get a steal-deal on a wrecked delivery truck with stick shift, then convert my bus. For example, a friend of mine delivers home heating oil around here, and his "little" Kenworth has a C-series Cummins with a full size 10 speed.
Meanwhile, I'm considering installing an extra cooler on my 643, with its own fan. But it has already made three trips over those mountains with no apparent harm.
Elliot
Old 02-28-2010, 09:10 PM   #6
Engine: 5,9 Cummins
MT643 -- max 250 HP, 640 lb ft, 73.280 Lbs GVWR; locks in 3rd and 4th,
Elliot
Mt643 or mt653 stryker International | Navistar Drivetrain 13 08-08-2015 11:48 AM
Tire code and service life news video frank-id Mechanical and Drivetrains 0 01-22-2010 12:17 AM
SVO life? Xtevan Veggie Oil | WVO | Biodiesel | SVO 1 10-15-2007 12:12 AM
A new life for a nice bus. westport_wayne Everything Else | General Skoolie Discussions 3 04-20-2007 12:42 AM
Does a MT643 fit instead of a AT545 ????? Protecx Conversion General Discussions 1 02-09-2007 09:14 PM
