Old 06-11-2015, 09:02 PM   #1
start and die
1995 thomas re with a 8.3 cummins engine, I crank the engine over and she fires off imediatly, let go of the key and she dies. hold the key and she stays running until I let off the key.
It is dark out now so I have to get a closer look tomorrow after work, but to me this sounds like maybe a fuel shut off solenoid/ or a relay? breaker? fuse?
I tried to use the rear start button and it did not work, but I have never tried it before so I am not sure if that is related.
Tomorrow I may try and get someone to turn the key over while I watch the pump solenoid.
any ideas anyone?
thanks
Cliff
c_hasbeen is offline   Reply With Quote
Old 06-11-2015, 09:16 PM   #2
any ideas anyone?
thanks
Cliff
I had something similarly quirky happen on a 1996 lincoln town car limousine.
Start the car normally, everything worked!
Turn off ignition and all electrical shut off, but engine kept running...
it would not die until I pulled the "drivetrain" fuse under the hood...
But get this, you could leave the fuse out, and car would start and have all electrical. But it would die at the most inopportune moment.
Electrical engineer wired a relay to the "normal on" wire under dash out to solenoid on fender under hood.
Chased that gremlin for months!
with you having the key twisted to the furthest right, you are closing contacts.... release the key and you are opening contacts.
Old 06-11-2015, 10:31 PM   #3
opus's Avatar
Chassis: All-American R/E
Unhook the fuel shut off solenoid and see what happens. You can of course manually throw the lever to shut it off.
Old 06-12-2015, 01:21 AM   #4
Engine: 190hp 5.9 Cummins
Your lift pump on the side of the engine block has failed.
When you hold the key on, you activate the small electric primer pump T'ed off the fuel intake line to the injection pump.
To verify this, disconnect power to the small electric primer pump. The engine will not start at all.
OR
Install a fuel pressure gauge in the same line the small electric primer pump is in using another T. Google what pressure you should have for that engine. Have someone stand there and watch it as you crank and start the bus.
Hope this helps.
Old 06-12-2015, 12:13 PM   #5
at lunch I put a piece of wood under the fuel shut off solenoid to hold it in the up position, started the engine from the front and she fired up immediately and idled just fine, however I did not have any dash gauges and the low air buzzer was not buzzing.
pilled the block of wood out and the engine died.
I will dig deeper after work if I get the lawn mowed in time
Old 06-12-2015, 12:16 PM   #6
Is your fuel shutoff solenoid air powered on your bus, or electric?
Glad you got her to idle.
Old 06-12-2015, 12:28 PM   #7
Nat, it is an electric solenoid.
Old 06-12-2015, 12:53 PM   #8
Ah good.
Should just be a simple two wire connection. Simple to figure out if it's the wiring failing, or the solenoid it's self.
Old 06-12-2015, 01:14 PM   #9
Ah good.
yea, it actually has three wires, I turned on the ignition to the run position and tested all three wires with a test light but no voltage present, I may talk the wife into turning the key to the start position tonight to see which wire is going hot when the crank over starts.
It should be a simple fix once I get to chasing down wires
thanks
Cliff
Old 06-12-2015, 01:33 PM   #10
Chassis: International 1753
Engine: 6.9 International
Did you check the ignition switch at all? Seems odd that the engine doesn't run and none of the gauges or buzzers work in the on position. It could just be as simple as that contact in the switch is bad.
