Re: Starting questions
I believe the 3208 also has the shut-off solenoid located somewhere in the valley between the cylinder banks. Make sure it isn't bad. I had one go out on a DD 8.2. It would run on ether, not on it's own. The solenoid shuts off the fuel supply to stop the engine. If it had been running O.K., it should be one of these two issues- lost prime or solenoid.
If it isn't grown, it has to be mined
