Old 09-14-2015, 01:25 AM   #1
steering gear box leak/pouring
All help will be most appreciated.I have a 99 Thomas 90 pass. flat nose w/ 5.9l /at545 combo. A few days ago I was backing the bus when I noticed fluid leaking from he gear box. A couple days later I notice it pouring out when in a turn. I proceed to check out the problem and when the gear box is n motion it pours fluid from the bottom bolt head under where the steering arm exits the gear box. Checked it and all the others and they where all tight. Any info will help. Thanx JP .
rollinmeadows is offline   Reply With Quote
Old 09-14-2015, 01:01 PM   #2
Chassis: International 1753
Engine: 6.9 International
A picture is worth a thousand words. If I had to guess, you have a bolt on seal for the steering gear that's leaking. But without being able to identify it for sure, I can't really help you.
