05-16-2017, 04:48 PM
Stuck throttle GMC Vandura Short bus
Anybody have advice? In driveway. Throttle/accelerator stuck wide open!
05-16-2017, 04:53 PM
Coachwork: Thomas Saf-T-Liner
I'm guessing it's cable operated throttle? Does the throttle cable move freely, no binding etc?
Sent from my Nexus 6P using Tapatalk
05-16-2017, 04:54 PM
Does it have throttle linkage or a cable?
05-16-2017, 04:55 PM
I think a cable
05-16-2017, 04:58 PM
I think a cable
What year is it?
Does it have a carb or fuel injection? Or is it a diesel?
Carb. 1990
05-16-2017, 05:01 PM
The part i can see moves. I havent gobe under yet. My bf sprayed the gas pedal with wd40. Was that bad?
05-16-2017, 05:17 PM
The part you can see, meaning the gas pedal?
Spraying wd40 on the pedal won't hurt anything. Most likely won't help anything either, though.
Open the hood and disconnect the air cleaner from the carb. Good where the cable is connected to the carb and unhook it. Should be pretty simple to unhook. If the throttle lever on the carb is free to move, then the problem is in the cable.
05-16-2017, 05:37 PM
Feel free to punish you bf anyway. Going around spraying gas pedals willy nilly.
Robin
Nobody's Business
05-16-2017, 05:39 PM
Lol!! I agree!!
05-16-2017, 05:42 PM
Yup.
Now you have to smell wd40 anytime you're sitting behind the wheel with the engine redlined.
05-16-2017, 08:31 PM
Year: 2006
Coachwork: Starcraft
Chassis: E350
Rated Cap: 12 Pas; 1 W/C
Last year my 2003 Class c motorhome (Gas V-10) cable was stuck, or that's what I thought,
when I opened up the air cleaner A mouse had eaten through the air cleaner, and packed the area with nesting and acorns up to the butterfly valve.
when i started the engine and opened the valve all the debris got stuck & held it open.
Luckily I was able to dismantle the air intake & vacuum everything out & there was no damage.
05-16-2017, 10:16 PM
Yeah, the acorns are such high fibre they pass right through.
Robin
Nobody's Business
05-19-2017, 12:13 PM
BF is not mechanical. Really would like to take bus out as she's all ready to go but how do i unstick the gas pedal? Anybody have a picture of a motor like mine? Trying to fina manual but no luck. 1990 GMC Vandura 3500 short bus.
05-19-2017, 12:49 PM
Take the air filter cover off and look at the rods or cables that run to the carb. Move them with your hands to see what is sticking. Might free things up then spray all the linkage with wd40. You will have to be the mechanic in the family I guess, lol.
05-19-2017, 01:36 PM
Originally Posted by Rameses
Open the hood and disconnect the air cleaner from the carb. Find where the cable is connected to the carb and unhook it. Should be pretty simple to unhook. If the throttle lever on the carb is free to move, then the problem is in the cable.
Did you try this?
I promise, I didn't suggest this just because I enjoy typing things out into the abysmal depths of the internet. I'm trying to help you find the problem, and this's the first step. If you need clarification on anything, don't hesitate to ask. And if you need any help identifying parts, post a picture and we'll point out what's what.
05-19-2017, 01:48 PM
Originally Posted by rameses
i promise, i didn't suggest this just because i enjoy typing things out into the abysmal depths of the internet. I'm trying to help you find the problem, and this's the first step.
rameses 5:1
05-19-2017, 01:57 PM
Ok! Thanks! Not yet!
05-21-2017, 01:07 PM
Ok. A guy came by and took the thing apart. Fuel-injection engine, no carb. Throttle was sticking. Cleaned it, put everything back. Says all else is well under there. Reached it from INSIDE the bus. 50 bucks. Thanks to all who tried to help.
05-22-2017, 08:56 AM
Sounds like a good guy for not overcharging you. Someone like that is definitely good to know if you don't have a whole lot of mechanical experience under your belt.
Also, that cover that allows engine access from inside the bus is called a doghouse. One of those terms that might be hard to figure out what somebody's talking about if you just hear it thrown out there.
Hope you're having fun driving it around!
