Old 05-16-2017, 04:48 PM   #1
Stuck throttle GMC Vandura Short bus
Anybody have advice? In driveway. Throttle/accelerator stuck wide open!
kjelenfy is offline   Reply With Quote
Old 05-16-2017, 04:53 PM   #2
Coachwork: Thomas Saf-T-Liner
I'm guessing it's cable operated throttle? Does the throttle cable move freely, no binding etc?
Sent from my Nexus 6P using Tapatalk
nwarner2010 is offline   Reply With Quote
Old 05-16-2017, 04:54 PM   #3
Rameses's Avatar
Does it have throttle linkage or a cable?
Rameses is offline   Reply With Quote
Old 05-16-2017, 04:55 PM   #4
I think a cable
Old 05-16-2017, 04:58 PM   #5
Rameses's Avatar
I think a cable
What year is it?
Does it have a carb or fuel injection? Or is it a diesel?
Old 05-16-2017, 04:58 PM   #6
Carb. 1990
Old 05-16-2017, 05:01 PM   #7
The part i can see moves. I havent gobe under yet. My bf sprayed the gas pedal with wd40. Was that bad?
Old 05-16-2017, 05:17 PM   #8
Rameses's Avatar
The part you can see, meaning the gas pedal?
Spraying wd40 on the pedal won't hurt anything. Most likely won't help anything either, though.
Open the hood and disconnect the air cleaner from the carb. Good where the cable is connected to the carb and unhook it. Should be pretty simple to unhook. If the throttle lever on the carb is free to move, then the problem is in the cable.
Old 05-16-2017, 05:37 PM   #9
Robin97396's Avatar
Feel free to punish you bf anyway. Going around spraying gas pedals willy nilly.
Robin
Nobody's Business
Old 05-16-2017, 05:39 PM   #10
Lol!! I agree!!
gmc, help please!, short bus, stuck, throttle
