Old 08-25-2010, 10:40 PM   #1
frank-id's Avatar
T444E need some care
These engines are a very good engine but do require some occasional new parts. The first item to need replaced are the small return hoses and usually the plastic caps. Some times the fuel filter will become restrictive. Most folks replace the filters, oil, add some Power Service and advance the fuel setting. The milage will dictate when most of the repair is needed. My 1990 Blue Bird has the same engine and an Allison. Aside from low power, I love this bus. Frank
Old 08-26-2010, 09:47 AM   #2
frank-id's Avatar
T444E
Go to your bus and look at engine. Try to track the fuel system. Try to identify all the engine components. The fuel system begins at the fuel tank, sometimes there is a in line fuel filter, goes to fuel pump, then to injector pump. Out of the injector pump to each cylinder injector. Excess fuel at each injector is routed to some small hose and returned to the fuel tank. Frank
How do we all feel about the T444E? thechandler Conversion General Discussions 26 03-09-2019 06:42 PM
INTERNATIONAL T444E RUNNING REALLYYY HOT nevrenufhp International | Navistar Drivetrain 4 05-18-2011 08:59 AM
98 366 running rough Jive Turkey Mechanical and Drivetrains 0 03-03-2011 04:11 PM
rough ride gasleroy Conversion General Discussions 1 10-06-2008 04:47 PM
rough ride! The Wanderer Conversion General Discussions 14 05-03-2007 11:31 AM
