Old 02-17-2017, 08:12 AM   #1
2kool4skool's Avatar
The value of oil analysis
Last years oil analysis showed high chromium and silicon.
I checked to intake tract and found the air filter rubber gasket was suspect but the biggy was the filter minder housing was cracked. It looked Ok but further inspection showed it's defect. I replaced both items and changed the oil.
Got my new analysis and the chromium is 1/3 what it was and the silicon went from 13 to 8, which is OK. All others are also ok, fuel 0, water 0 etc.
$28 plus under $4 shipping for piece of mind and this year's oil change will be done next year (under 4000mi per year).
Helpful hint: Through experience of myself and others, I found that sending the sample in the supplied black container to Blackstone resulted in a up to 3 week delay. Dropped the container into a small box got there very quickly! Mailed on Sunday, rec'd on Wed.
Don, Mary and Spooky the cat.
Old 02-17-2017, 08:31 AM   #2
Phatman's Avatar
Thanks for the tip 2kool4skool.
