01-23-2018, 08:26 PM
#21
Chassis: Saf-T-Liner MVP ER
Originally Posted by BullCityBus
I was just about to ask what y'all thought about the 545 & the 5.9 Cummins....From the searching I've done it seems like the transit style Blue Birds seems to come with the Cummins more often that the Thomas busses I've seen, mostly CAT engines there. The Blue Birds seems to also come with the 545 most of the time too. So I gather I should keep my eyes open for something better or just factor in an eventual upgrade?
Sent from my Pixel 2 using Tapatalk
It's vastly cheaper to find one specc'd the way you want it, than to upgrade later.
We just had one upgrade, albeit to a brand new MT643, for $5000. That's $1000 more than my 40' Thomas pusher with Cummins 8.3L and MD3060 cost in the first place.
Remember, buses don't come with engines. Buses get the engines the School wants, picked from a list at varying prices. The bigger CATs, DT466, DT530 and Cummins 8.3L are all expensive options. They don't go into route buses in most states.
They do go into Trip and Activity buses, in many states, and those buses also have an easier life on the road.
Plenty of them come up for sale, at decent prices, but you may have to be patient.
01-23-2018, 08:46 PM
#22
Depends. On how you want to use the bus. The terrain, the speeds, roads, etc.
Its probably best to find one with a better trans from the get-go. The 545's are always mated to a lower-hp engine even if its a DT466. But it really does depend on what kind of use your bus will see.
01-24-2018, 06:20 AM
#23
It'll be used for full time living and we plan on travelling, so I think I'll add a better transmission to the search list!
01-24-2018, 07:00 AM
#24
Year: 2010
Coachwork: Thomas B2B
Chassis: 281TS
Engine: MBE 926 7.2L 211HP
Rated Cap: 29,000 LBS
I’ve heard about CATs, Detroit Diesels and Cummins but what about Mercedes 900 series engine? How good are they?
01-24-2018, 09:43 AM
#25
MB's are kinda' like Cats. As long as nothing goes wrong, they are fine. But if anything goes South...be prepared to spend WAY more money repairing them than any other engines. Parts and service on both can be crazy expensive.
01-24-2018, 09:45 AM
#26
Year: 2010
Chassis: 281TS
Thanks Tango for the feedback!! I’ll keep my fingers crossed and hopefully all goes well on the road trip!
01-24-2018, 11:07 AM
#27
You are most likely to find Mercedes engines in newer Thomas Built, because Daimler owns both companies.
Quite a few of our School fleet have them.
01-24-2018, 01:13 PM
#28
Originally Posted by Twigg
A note on the CATs. There is little evidence that they are more prone to breaking, at least not the 2004 and earlier.
Indeed, they are more resistant to over-heating than are engines with wet liners.
How do we know this? NB: I don't own a bus and I know nothing about large diesels. What I know I heard here. But, this "wet sleeve engines are more prone to overheating" is new to me. I've heard it here, but only a couple of times and only in the last year or so.
Are you saying that "Cats are more resistant to overheating" or "parent bore engines are more resistant to overheating"?
Thanks.
01-24-2018, 01:16 PM
#29
Originally Posted by Jolly Roger bus 223
....I am working on a gas line and heaters for a Detroit and Allison shop where the mechanics are happy to talk in spurts.
While you're talking to them, find out what you can about unlocking 6th in a 3060. Is it against their religion? Will they do it after hours for a couple of Benjamins? Are they scared silly of being sued by Allison if they get found out?
Enquiring minds want to know.
01-24-2018, 01:18 PM
#30
Parent bores tolerate heat a little better
They don't have liner seals to fry.
01-24-2018, 01:20 PM
#31
Aaah; thanks.
01-24-2018, 04:12 PM
#32
Year: 86
Chassis: Ford B700
Engine: 8.2
I will the last time I was there they had 3or 4 3060's out and on the stands and I asked what was going on with them and the mechanic opening one up said that they have to replace the front pump bearings in two or three a year.
But I will talk to them more about the 6th gear idea
07-23-2020, 06:19 PM
#33
Chassis: MVP
Engine: CAT 3126A RE + MD3060
Rated Cap: 84 kids or 56 adult
And...pins and needles here...?
