Old 04-25-2018, 11:11 PM   #1
Coachwork: Bluebird All American Farber
Engine: 8.9 Cummins
Tilt steering.....
So, the tilt steering positioning lock has died...I am curious as to find a replacement and am not sure where to find it. Does/did Bluebird manufacture their own steering columns or is that a “GM” or “Ford component purchased in bulk....just looking for direction....
Thanks
Oh, got carpet out and decisions have been made about flooring and walls. 3/4 yellow pine and vinyl plank.
File Type: jpg D176853A-1280-4AC4-BF1C-155F65E0DB7D.jpg (104.5 KB, 8 views)
File Type: jpg 1BF27534-85A2-4526-A892-AF873FEE4384.jpg (330.0 KB, 8 views)
Plyman is offline   Reply With Quote
Old 04-25-2018, 11:30 PM   #2
Can you clarify a little - was it working, and stopped working? Is it stuck in one position, or freely moving without locking in place?
The reason I ask is I have a 1999 TC-2000 FE - not sure if mine has the same steering assembly as yours, but evidently my bus must have had the same driver forever - and that driver liked the steering all the way forward. Mine had sat in that position for so long that it either rusted or gunked up with crud into that position. I tried brute force over and over again and finally shot some WD-40 up into the mechanisms and kept yanking it until I felt it start to break free. For a week, I made it a point to move it back and forth a couple times a day at least. Now it's as smooth and easy as can be and the lock works like a champ.
TrailLifeBill is offline   Reply With Quote
Old 04-25-2018, 11:51 PM   #3
Engine: 8.9 Cummins
It won’t lock, sorry...it was doing just fine and....poof
