Old 12-01-2016, 09:35 AM   #21
Coachwork: Bluebird?
Chassis: 26ft Bluebird TC2000
Engine: Cumming 5.9 12v, AT545
RTO in granny low for getting unstuck?
dalez is offline   Reply With Quote
Old 12-01-2016, 12:50 PM   #22
Chassis: Blue Bird
Engine: ISC 8.3
Originally Posted by cowlitzcoach View Post
You may just want to carry along some sheets of plywood. Before you head off of the road and head out over the grass put the plywood down where you are going to park. Keep the hammer down until you have the front tires on the plywood. Spreading the weight that far out will not likely result in you getting stuck.
In a similar vein, what about sand ladders? It'd be a lot of hassle if it had to be done with any frequency. On the other hand, the point is well-made that at some point the surface is so soft that ordinary wheels, driven or not, just can't get a vehicle across. (I haven't invested much thought into what length, width, and thickness would be required to make a sand ladder functional under the weight of a bus!)
Old 12-01-2016, 01:58 PM   #23
I imagine 'sand ladders' for a 36+klb gvwr bus would be a PAIN indeed, although maybe I should consider them for the worse of conditions.
A friend suggested tire chains on the duallies with square tubing laid across the tires, chains thru the tubing to make cross-bars....
