Originally Posted by cowlitzcoach
You may just want to carry along some sheets of plywood. Before you head off of the road and head out over the grass put the plywood down where you are going to park. Keep the hammer down until you have the front tires on the plywood. Spreading the weight that far out will not likely result in you getting stuck.
In a similar vein, what about sand ladders? It'd be a lot of hassle if it had to be done with any frequency. On the other hand, the point is well-made that at some point the surface is so soft that ordinary wheels, driven or not, just can't get a vehicle across. (I haven't invested much thought into what length, width, and thickness would be required to make a sand ladder functional under the weight of a bus!)
