Old 08-02-2013, 10:11 AM   #1
Chassis: Saf-T-Liner MVP
Engine: Cummins 6BT
tractor hydraulic fluid, can I use it?
Hey all,
So I have been going through some stuff I have around lately and ran across 2 5 gallon buckets of 'tractor hydraulic fluid' I got with my first bus (1986 international, dt466, at545). I am wondering if this is usable in that bus or in my new bus (1990 thomas saf-t-liner mvp, cummins 6bt, at545) and if so what system? i never was exactly sure why it was in the bus, but i did buy it from a farm, so maybe he was just storing it in there? I dont want to keep hauling it around if i dont need it, but would be more than happy to if it is. the coolant system takes coolant, engine takes oil, brakes and auto chains air, tranny takes dexron, so where would i use this, if at all? thanks for the help!
jlhollowx13 is offline   Reply With Quote
Old 08-02-2013, 10:18 AM   #2
JakeC's Avatar
Re: tractor hydraulic fluid, can I use it?
Believe it or not, I believe the transmission. Allison even has a service bulletin out on it. I'll look it up for you, though.
Brutus
Old 08-02-2013, 10:19 AM   #3
wmkbailey's Avatar
Engine: 3126
Power steering does, but you don't need 10 gallons of it.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 08-02-2013, 10:32 AM   #4
JakeC's Avatar
http://www.allisontransmission.com/serv ... 1494EN.pdf
Approved C4 list
Btw...don't tell anyone, but this is what I'm running in my MT643. Shifts are firmer and transmission runs perfectly cool.
Brutus
Old 08-02-2013, 11:58 AM   #5
Engine: Cummins 6BT
sweet! well it looks like ill hold on to it for the time being. it might come in handy in the future!
Old 08-02-2013, 12:11 PM   #6
JakeC's Avatar
But first check it to make sure it has the Allison C-4 rating. And I would recommend doing some research. I did enough research to determine I was comfortable putting C4 rated motor oil in my trans, but don't just take my word for it. This post is my opinion...I do not recommend...blah blah blah...
Brutus
Old 08-04-2013, 08:46 AM   #7
bapos's Avatar
I know in the demolition derby world lots of people use them in cars. Granted most guys blow up trannys on a regular basis and they get rebuilt but I know many very high dollar cars run it. As Jake said... I would make sure its compatible but unless its some generic made fluid they usually manufacture to standards of most manufactures spec... that way they can sell more product.
Here is my school bus conversion thread http://www.skoolie.net/forum/viewtopic.php?f=9&t=10282
Pics of my conversion @ photobucket http://s18.photobucket.com/albums/b1.../School%20Bus/
What is this fluid reservoir? hojjifiremaker Mechanical and Drivetrains 5 06-02-2013 04:26 PM
Whats that fluid in the heater butcher_boy Conversion General Discussions 2 05-13-2010 03:52 PM
1991 BlueBird TC2000 Hydraulic/Hydraulic Brakes Sticking C00LR Mechanical and Drivetrains 0 10-15-2009 10:11 AM
Transmission fluid issues. GoneCamping Conversion Tutorials and How-to's 0 07-23-2008 09:42 PM
Air vs. Hydraulic pangaia Conversion General Discussions 8 12-13-2004 07:34 PM
