Old 09-14-2018, 05:14 PM   #1
Tranny questions
Im looking at a bus that has a 366 cc engine and 5 speed manual transmission.
Im totally new to all this. Anybody have thoughts on the quality of the engine?
Also the transmossion wont go into 4th or 5th gear. Idk if its worth it to get. My plan is not to drive this thing a ton. Im planning to park it on land but want the option to move it when needed. Its also been insulated and has doar installed plus a wood stove. So basically the daunting parts for me are done, the rest of it i can muddle through building and installing.
Thnx
Scaredy bus is offline   Reply With Quote
Old 09-14-2018, 06:12 PM   #2
Personally I would shy away from any bus that needs mechanical work up front. If you take the cost of repair added to the purchase price most times you could have bought a better bus for the same or less.
Price would be a determining factor here on whether it's something you should consider.
Old 09-14-2018, 06:15 PM   #3
Welcome Scardey,
To be perfectly honest, if it is a full size bus, it is probably worth close to $1000 if it runs well enough to get to the recyclers under its own power.
Older gas buses are underpowered, shorter lived and generally get poor fuel mileage compared to recent diesels.
A gasser bus with a broken transmission is not very attractive when we see decent diesel buses with working transmissions sell for $1500-$4500 all day long.
Here is a DT466 powered, 5 speed bus that is currently at $1500 at auction. https://www.govdeals.com/index.cfm?f...22&acctid=2192
Auctions sites:
Government Surplus Auctions - govdeals.com
www.publicsurplus.com
www.purplewave.com
422 Sales
www.rbauction.com
Take a look at the classifieds on skoolie.net as well.
Good luck on your quest.
Old 09-14-2018, 06:35 PM   #4
They are adking 5000 obo, i plan on offering 4000.
I was thinking it might be worth it because it already has the solar and insulation and flooring and woodstove installed. But im so new ay all this.
Old 09-14-2018, 06:39 PM   #5
Got any pics of it? Unless the conversion is the way you want it that's a high asking price. Sounds like a bus I would buy for $1k so I could put everything into my bus.
Old 09-14-2018, 07:01 PM   #6
Thanks for the info!
Old 09-14-2018, 07:31 PM   #7
Trying to figure out pics on here..
Just looked back at my first post. Ugh i fat fingured that. * it has been insulated and has solar set up and wired plus the flooring and a wood burning stove.
Old 09-14-2018, 07:39 PM   #8
Those things could be assets or liabilities depending on how they were done. How much insulation, how much solar? I just bought a wood burning stove for $100.
Old 09-14-2018, 09:39 PM   #9
Sweet! Good questions! I will find out thanks
Old 09-14-2018, 09:41 PM   #10
Thanks ill do that
