Old 07-16-2012, 08:06 PM   #1
tranny temps
Ok so I have an A545 I know it slips with out lockup option.
I noticed sunday that at 55mph flat ground temp was around 180/190 engine temp(since tranny cooler is in radiator)
On a few smaller hills,giving throttle to maintain speed that engine temp(per gage) engine temp would be close to 200,but the tranny temp climbed quickly to over 220,I backed out and once it settled down to cruise speen temp dropped quickly to 190.
I know 180/190 is best to evap water molecules but I don't want to "varnish" or burn tranny fluid.
Tranny is full and has good color and no burnt smell.
I will be adding trany cooler/s to manage temp.
What is normal for this trans,hell 230 on gage is "buried" just curios....what say ya'll?
Old 07-16-2012, 08:28 PM   #2
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: tranny temps
Since I just put a tranny temp gauge this spring, my observation is that outside air temp has alot to do with the overall temp. ( Stock Ford tranny-cooler in the rad + small factory aux cooler.) I've done the same 200 mile trip and had the average temp vary 10-15 degrees from running in the day to running at nite. The heat of the day I'm running 185-drop the air temp 15 degrees and its 170-175. Worse was towing up a 1 mile hillclimb at 20 mph towing a trailer-210 degrees.
Old 07-17-2012, 09:33 AM   #3
Re: tranny temps
i dont want to go much over 200 or so on the temp gauge.. the main thing is to not floor the gas petal when its clear that the bus won't go any faster anyways up a hill.. its also why its a good idea to keep watch of the engine temp gauge.. the bus can always be parked for a bit while it cools off in the hills...
my son in law drives occasional trips to games, etc in the winter and he said he just keeps the acc petal on the floor all the time while going up hills... course it aint his bus... i think this is one of the reasons busses frequently have reman trannies when they are sold.. mine did.
Old 07-17-2012, 02:06 PM   #4
opus's Avatar
Chassis: All-American R/E
Re: tranny temps
You really dont want to hit 200.
Old 07-17-2012, 02:42 PM   #5
Re: tranny temps
prefer 180.
allison site says trans should be properly warmed up before operation.
like that is going to happen in normal school bus operation...
its a good idea for people to read about trans operation on that site. fwiw
Old 07-17-2012, 03:51 PM   #6
Re: tranny temps
mmm according to page 21 of the manual:
sump fluid,minumum continuous=100*
sump fluid,typical continuous=200*
converter out fluid,maximum=300*
retarder out fluid,maximum=330*
sump fluid,maximum=250*
So I need to see where the gage is located and see where the temps are being taken
Old 10-09-2012, 11:03 AM   #7
Re: tranny temps
Tranny fluid can lose its lubricity in one mile on a hard pull.
Literally, start a transmission that is perfect with hot fluid, burn it on a hard pull...and one mile later it is toast.
100% synthetic fluid will prevent a ton of issues from heat.
The synthetic ATF retains its "goodness" into the 400 degree realm. (Your gaskets melt at that temp)
Have any of you heard the RV people that say to pull the trans out of OD (and out of lockup in many cases) on the hills? LOL
caseythenose is offline   Reply With Quote
Old 10-09-2012, 11:06 AM   #8
opus's Avatar
Re: tranny temps
So thats why that sticker is on the dash. ;)
Old 10-09-2012, 12:08 PM   #9
Re: tranny temps
I am getting ready for a trip that is going to be hard on the tranny for sure.
It is the grade into Boone NC on HY421 it's not a long grade but at spots it's 12-19%.
Plan is to go slow,keep engine about 1800 RPM and 1st or 2nd gear...that coupled with all 5 heater fans on high...and stop if needed.
I have searched with no luck ...what is the "correct" way to drive up hills with 5.9 and the A545?
I have seen mention that the A545 has full pressure at 2400 RPM (thats kinda high isnt it?)
What would be ideal for rpm for keeping air moving from fan?
I have added a few electric fans I had laying around to try to keep air moving when bus is moving slow
Good thing I have a 190 amp alt. with all the fans on I'll need it of course the alt will make the engine work harder
Also it was a 95* day when I had the initial heating up..or original post.
It will be about 50* cooler when we head out.
I have recon'd the hill and possible pull offs, and planning the drive during the slowest traffic times with work schedules and class schedules.
Fingers crossed
Old 10-09-2012, 01:43 PM   #10
GreyEagle's Avatar
Re: tranny temps
Take care of that tranny....... Here are a few links with good info........ I figgured you'll need it , if you get up that hill!!!!! LOL Enjoy your trip...
DOWN-LOAD-ABLE ....... http://www.allisontransmission.com/serv ... 1321EN.pdf
http://www.allisontransmission.com/publ ... onType=All
http://www.messb.com.my/allison_at_545.html
School Bus, Intercity Bus and Shuttle Bus Rating
Net input power 235 hp (175 kW)
Net input torque 445 lb-ft (603 Nm)
Vehicle weight Up to 30,000 lbs (13,608 kg) GVW
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Its freezing temps, motor ok? Jaybus Ford Drivetrain 3 10-26-2011 11:40 AM
Passive solar hot water temps? Diesel Dan Conversion General Discussions 11 01-26-2010 06:03 PM
how to tell which tranny putterspitt Conversion General Discussions 2 10-27-2009 03:18 PM
Oil/Tranny analysis NewSkewlHauler Conversion General Discussions 1 04-20-2009 01:02 PM
Tranny Doc Conversion General Discussions 0 02-08-2005 05:06 PM
