Old 12-31-2017, 07:39 PM   #1
aridgedell's Avatar
Chassis: Thomas
Turn signal lever
2001 Thomas Saf t liner Cummins and allison.
So I'm taking care of some mechanical issues on my bus before I keep going with the conversion.
The turn signal lever was broken and I have a replacement for it now. I havnt been able to figure out how they come out. It is broke off almost flush.
Any help or where to find info on how to replace it would be great! Thanks!
Sent from my SM-N950U using Tapatalk
aridgedell is offline   Reply With Quote
Old 01-01-2018, 02:07 PM   #2
Year: 90
Chassis: international
The type of lever in the pic is the type you wiggle and pull. You may need to get a good grip on it but it should pull out. If not you may need to change the whole assembly.
Old 01-01-2018, 03:23 PM   #3
aridgedell's Avatar
Chassis: Thomas
ok thanks, I'll give it a shot.
Old 02-16-2018, 11:46 PM   #4
golfersmurf57's Avatar
If all else fails signal stat makes a wraparound column unit. It's pricey but will work. Or do like the city buses put a push button for each direction on the floorboard under your left foot. Old fifties starter buttons will work great LoL.
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 04-22-2018, 06:10 PM   #5
aridgedell's Avatar
Chassis: Thomas
sprayed a little oil on it and it pulled right now new one snapped right in
