Old 04-17-2011, 06:27 AM   #1
Seeria's Avatar
Two starting batteries?
My bus came with two starting batteries and I was told that they were used to run the wheelchair lift. Since the bus no longer has the lift, do I still need TWO starting batteries?
95 International diesel DT466
Seeria is offline   Reply With Quote
Old 04-17-2011, 04:54 PM   #2
Engine: 466DT
Re: Two starting batteries?
Diesel engines work off compression. So they have a higher compression ratio compared to a gasoline engine. They use the compression and heat to "ignite" the diesel fuel when it is injected into the cylinders. Unlike a gas engine, that uses spark plugs that ignite the gasoline. So basically that means, it is harder to turn over the engine to get it started. You will want to keep both batteries for starting.
Hvbuzz is offline   Reply With Quote
Old 04-17-2011, 05:34 PM   #3
Seeria's Avatar
That's what I needed to know Thanks guys
Old 04-17-2011, 09:31 PM   #4
lornaschinske's Avatar
We start our diesel engine with one 12v battery. We also started our Eagle (8v71N65) with the same size battery, We used to start the Eagle during the winter with the single 12v battery
Fulltime since 2006
Old 04-18-2011, 06:18 AM   #5
Seeria's Avatar
hmm what size battery, Lorna? I've the DT466 (1995) and it has International brand batteries but I can't read what type. Maybe if I upped the size a bit and just bought one?
Old 04-18-2011, 09:36 AM   #6
Stuff's Avatar
or just get one big one
Old 04-19-2011, 08:34 PM   #7
Wal-Mart Everstart pt #36R-3 810 amps 650CCA is what is starting the bus (and we use it to run the food cart's 12vDC stuff as well.
Fulltime since 2006
replacing 8d starting batteries gbstewart Electrical, Charging and Solar 11 05-09-2014 10:48 PM
Starting questions ezbme Mechanical and Drivetrains 1 04-13-2010 09:39 AM
best starting platform budd0413 Conversion General Discussions 4 02-17-2010 07:21 AM
starting the project bocephus Conversion General Discussions 0 02-02-2006 07:18 PM
Starting the Conversion finfan3dp Skoolie Conversion Projects 0 12-04-2004 05:43 PM
