Old 06-18-2009, 07:44 AM   #1
Re: Water in fuel? (Diesel)
get the water out of the system, install a raycor or similar water seperating fuelfilter before the injection pump, open the lines at the injectors and flush the ip and lines of all contaminated fuel, siphon/drain the water out of the bottom of the fuel tank, bleed the fuel system and only then try to start the engine and hope that no damage has been done. the biggest danger of running water contaminated fuel is the possibility of blowing the tips off of the injectors, the high viscosity of water along with its ability to expand something like 1000 to one when it converts to steam is a real issue to be concerned about. if/when the injectors self destuct the next issue is how much damage will the debris do to the pistons/cylinders.
Old 06-18-2009, 06:13 PM   #2
frank-id's Avatar
Add rubbing alcohol....... Frank
Diesel Fuel Stabilizer reprobate Conversion Tutorials and How-to's 5 10-05-2011 08:44 PM
Fuel tank for black water bluebird90 Conversion General Discussions 13 04-14-2011 07:21 PM
how much diesel fuel? gbstewart Conversion General Discussions 14 02-06-2011 09:06 AM
Fresh water tank for fuel? BUSBOZO Conversion General Discussions 6 10-13-2010 12:13 PM
Diesel fuel pricing. Train-train On the Road | Travel, Trips, Camp Sites, Tailgates 1 12-09-2007 04:02 AM
