Old 06-09-2016, 05:02 AM   #1
TygerCub's Avatar
Engine: Detroit
Water in Fuel warning light... how to drain?
Hi guys. I haven't posted in ages, but I'm finally able to get the bus back on the road and ran into a "Water in Fuel" light on the dash.
Does anyone have a photo or description of where the water drain is on a 1995 Genesis short bus? I'm ready to get this puppy back on the road and don't want to blow it up before I get out of the neighborhood.
Old 06-09-2016, 06:33 AM   #2
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
there should be a fuel filter next to the engine with a peacock on the bottom. drain it, turn the key on for a few seconds shut back off and then close the peacock.
my build pics
Old 06-09-2016, 06:44 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
They aren't all alike and may have been added after the sale. It will probably look like one of these. Probably in the engine compartment.
https://www.google.com/search?q=filt...ater+separator
Like superdave said there should be a petcock on the bottom. If it is the kind with a glass bowl, simply drain until the water is out. (it will be a different color, you can tell)
Old 06-09-2016, 08:21 AM   #4
turf's Avatar
i've drained a few of these separators, and if you are on concrete, its messy and you'll smell like diesel until your next shower. you might try using bottle or something to catch the water.
fwiw
Turfmobile Build Thread
Old 06-09-2016, 09:05 AM   #5
The standard filter is on the engine but it may have a separate fuel/water separator as well. Trace your fuel lines back to the tank to see what else might be there. Any such filter will have a simple petcock/drain on bottom. Definitely have a pan or bucket handy...it is a messy task.
Old 06-09-2016, 11:01 AM   #6
dont drain too much or you may lose main pump prime if you are mechanical with a suction type fuel system..
any idea those here or may know, what triggers that light to come on?
Old 06-09-2016, 11:18 AM   #7
I believe most of the "E" engines have a simple detector on the filter.
Old 06-09-2016, 12:13 PM   #8
Chassis: AARE
[QUOTE=cadillackid;151795
-Christopher[/QUOTE]
Water
Ok, can something be done about the need to post a bunch of unnecessary words?
Old 06-09-2016, 12:38 PM   #9
Chassis: International 1753
Engine: 6.9 International
Most I've seen have a float in the primary filter/water separator that will float with water but not fuel. There also should be some sort of petcock on the bottom of it to allow it to drain. The filter is usually under the bus on or near a frame rail.
Old 06-09-2016, 06:08 PM   #10
TygerCub's Avatar
Engine: Detroit
Thank you to everyone who answered. Using the 'trace the fuel line method', I was able to find the filter (I never would have guessed it would come out of the TOP of the tank instead of the side or bottom ). Drained some fluid from it, but it was next to impossible to see any differentiation in color from my position under the bus, so I had to guess when to stop. How much water is necessary to make the water light go off? How much fluid is "too much" and puts me in danger of losing the pump prime?
Old 06-09-2016, 10:39 PM   #11
TygerCub's Avatar
Engine: Detroit
BTW, for anyone with this model bus, the filter was on the driver's side, inboard of the frame, in front of the muffler.
Old 06-10-2016, 09:58 AM   #12
If it's a clear bowl then the separation between the water and fuel should be obvious. If you're getting nothing but fuel out of the valve then you might have a bad sensor.
Old 06-13-2016, 09:02 PM   #13
TygerCub's Avatar
Engine: Detroit
Filter is a solid white canister with a large red knob on the bottom for the drain. Whatever I got out of it seemed to do the trick. The bus ran perfect on the trip (1400 miles there and back again). Thanks again to everyone who offered advice.
Old 06-14-2016, 08:32 AM   #14
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Dapplecreek is offline   Reply With Quote
Old 06-14-2016, 08:35 AM   #15
Laughed my a$$ off!. Nicely done.
Old 06-14-2016, 08:52 AM   #16
It's actually quite tempting to find some sort of rubber peacock head and glue it onto a fuel separator on a random bus. Nobody would see it for quite some time, of course, and the guy who did might not get the gag. But if he did, I would imagine his reaction would be priceless. And just knowing that I set such a time-bomb for someone would be quite gratifying...
I used to be a high-school science teacher. Can you tell?
drain water, genesis, water in fuel
