Go Back   School Bus Conversion Resources > Skoolie Tech > Mechanical and Drivetrains
Click Here to Login
Old 03-09-2015, 06:39 PM   #1
Chassis: All American RE
Engine: CAT 3208 10.4 liter 250 h
What fluid in the differential of a 1989 78-passenger BlueBird All-American
So, I sheared off an axle, and found a replacement, but it is sitting on a bit of an incline, with that axle downhill, so I've lost probably 3/4 of the fluid out of the diff. What fluid do I add, and should I drain it completely and put in all fresh?
I've looked around, and found a tag on the diff that's hard to read, but I can make out "Rockwell International", and the model looks like it might read R 125NX 7
Thanks
BlunderBus is offline   Reply With Quote
Old 03-10-2015, 12:46 AM   #2
Rated Cap: 40 Prisoners
check out this link, You probably need a GL-5 lube and the type of differential will determine the viscosity. http://www.wanderlodgeownersgroup.co...E%20MANUAL.pdf
Old 03-10-2015, 09:22 AM   #3
Chassis: International 1753
Engine: 6.9 International
Gl-5 rated 75w140, we use Valvoline but whatever brand you feel loyal to will work. If it has limited slip or is a two speed you might have to include a friction additive in the fluid for it to work properly.
axle, bluebird, differential, fluid, oil
