Old 12-17-2012, 01:10 PM   #1
What is the power cord on the motor area?
1986 Blue bird ford international 8 cyll I Think 7.3 motor.
When I plug what ever dangling cord visible from under the front wheel it trips the breaker on my 110V home current.
1. What is it?
My thought was to keel the batteries and the motor from freezing?
Jaybus is offline   Reply With Quote
Old 12-17-2012, 02:05 PM   #2
GreyEagle's Avatar
Re: What is the power cord on the motor area?
More than likely it's a block heater for extreme cold weather. Diesel engines are known to he hard to start in the winter time...... Kicking the breaker ..... probably short in the block heater system or cord..
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 12-17-2012, 02:26 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Most of those are 1500w, you might check to see if a 1500w heater will also blow that breaker.
Old 12-17-2012, 10:07 PM   #4
opus's Avatar
Chassis: All-American R/E
If you are plugging into a GFI outlet, it will probably trip it. Especially if its an "in block" heater.
Old 12-18-2012, 12:34 PM   #5
frank-id's Avatar
GFI means ground fault interruptor
These clever devices measure and voltage leak to ground. A in block heater will not trip a GFI any more than any other circuit. Some GFI are slow and lazy and can do a bit of unnecessary tripping. These are a valuable device in most applications. I have also removed same under certain conditions. Frank
Old 12-19-2012, 10:52 PM   #6
opus's Avatar
Re: GFI means ground fault interruptor
Hotstart told me specifically that block heaters will trip GFI plugs a lot of times. More than a circuit breaker. I surely wouldnt remove a GFI though.
Cheap extension cord to connect batteries vince4242 Alternative Fuels | Electric, Propane, Wood & Biofuels 7 11-13-2012 04:14 PM
Which bus/motor would you get if you did it over? KC10Chief Mechanical and Drivetrains 36 03-03-2009 05:08 PM
Shore power cord storage JonCBrand Conversion General Discussions 3 01-24-2007 01:24 PM
ATX PC Power Supply to a 12 Volt Power Source vonslatt Everything Else | General Skoolie Discussions 3 02-15-2006 06:57 PM
Motor and trans info on a 1979 ford gas motor auto trans highvoltage21733 Conversion General Discussions 3 10-28-2005 09:31 AM
