07-17-2016, 06:18 PM
What kind of tranny fluid?
I'm sitting here at a truck stop and found I am 2 quarts low on tranny fluid, but don't know what kind to put in. Can anyone help?
This is a 1991 International Thomas school bus, with a 7.3 diesel. I called a parts store and they seems confused but said Mercon V. However, online I read that you can't use the Mercon V on this engine unless it is 2006 or later. Does anyone know? Also, the dipstick says to check it in neutral, but is that with the engine on, or off?
I'm afraid to continue through these mountains until I get this taken care of. I would be most grateful if someone is able to answer.
Thanks!
07-17-2016, 06:58 PM
Chassis: AARE
Engine: 3116 Cat 250hp
Engine has nothing to do with what kind of transmission fluid to use. If it's a full size bus it's probably an Allison. Info here
Approved Fluids
Dick
07-17-2016, 07:07 PM
I just looked at the tranny label and it says it is an Allison AT545D. I don't understand what their website means with those tabs that say TE 295, etc. What am I missing here?
07-17-2016, 07:19 PM
I run dexron 3 in my 1993 AT545.
TES 295 is a specific synthetic grade standard. you can run synthetics but they cost more.
07-17-2016, 07:33 PM
Chassis: AARE
TE 295 is an Allison rating for synthetic fluid. If it meets the spec it WILL say so on the label.
07-17-2016, 07:39 PM
And just in case you missed it, check fluid with transmission warm, on level ground, *WITH* engine running. Dipstick should even have this printed/stamped on it.
07-17-2016, 08:13 PM
In neutral. If not warm, there's a mark for cold on the stick.
Dex 3 is fine in a 545
Don, Mary and Spooky the cat.
07-17-2016, 08:43 PM
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
Just a quick comment: the TES-295 APPROVED (not the "equivalant" or "compatible" fluids are now the "official" fluid for the Allison transmissiojs. This fluid is really an amazing bit of chemical engineering. It shifts better, resists oxidation better, and it will retain its beneficial properties far longer than non TES-295 fluids. In a word this stuff is excellent. You WILL feel a difference (as will your wallet. Oy!)
There are some who use the cheaper fluids to good advantage, and I was one of them. Not a darned thing wrong with the original fluids, and in light of fact, thousands of school busses and transit busses use these "old" fluids every day without any issue. But honestly, if you are pulling hills or doing long desert drives, the TES-295 fluid simply can not be beat. Its amazing stuff.
Tl/dr; TES-295 is the preferred (and Allison-specified) fill. Great stuff. Works good. But you can use the old fluid just fine if you are not beating on it.
07-17-2016, 10:18 PM
FWIW, since I recently changed trans fluid to Super Tech (WM) Dex 3 my 545 hasn't made the classic 1st to 2nd squeal. Have quite a few miles and lots of 6% grades towing.
Unknown what was in the trans.
07-18-2016, 01:37 PM
I ended up using what the gas station had, which was something that said it was Dexron III and rated for Allison off highway C4. Not ultimate I suppose. I'm going to read through this read a few more times and see if I can wrap my head around this.
07-18-2016, 02:17 PM
wow, i just learned something. let me pass on that tidbit of knowledge to you.
here is a quote off a different website, same topic.
TES-295 fluids are full synthetic DEXRON3 fluids and TES-389 fluids are conventional DEXRON 3 fluids certified to be safe for Viton seals. These are considered fluids for "on-highway" use applications. (The TES-468 is a subset of TES-295 full synthetic, but for use in hybrid bus transmissions where ensured compatibility with the electrical components is important.)
