Old 04-06-2015, 09:27 AM   #1
Chassis: B3800 Short bus
Wheel types: Dayton and Budd. Pros, cons and other info
G'day.
This conversation occurred in another thread recently and I think that it's good information to have easily accessible.
Original thread: I am thinking about this one
Firstly, this is a Budd:
And this is a Dayton:
Please note that no modern Dayton wheels use split-rims! If you have a Dayton wheel with a tire that requires an inner tube you may have split-rims. If you're running tubeless then you don't.
Dayton wheels (spoke wheels; wagon wheels)
  • Pros:
    • tires can be changed with a breaker bar, torque wrench and something on the ground to check trueness of wheels;
    • The donut shaped and lighter rim makes it easier to lift and move a spare into place (though still freakin' heavy);
    • usually 5 or 6 lug nuts to remove;
    • they look gnarly.
  • Cons:
    • takes some work to get them true;
    • can slip if not tightened properly;
    • it's possible that some shops will charge more to work on them (just a guess);
    • they look gnarly (this one is obviously subjective )
  • Other info:
    • recommended dry torque of 200-260ft.lbs for 3/4"-10 studs; 150-175ft.lbs for 5/8"-11 studs.
Budd wheels:
  • Pros:
    • Always true (unless damaged);
    • clean looking;
    • all heavy-duty shops can work on them.
  • Cons:
    • Spare + rim is effin' heavy;
    • 3/4" drive impact wrench required to remove lug nuts;
    • 6-10 lug nuts to remove;
  • Other info:
    • Recommended dry torque of 450-500ft.lbs.
I did my research on the subject before purchasing my bus, but - at the time - didn't really care one way or the other. In the end I'm glad I have Daytons since I can deal with them myself; whether on the road or in the driveway. I've had most of the wheels off at one point or another and put them all back. They aren't very difficult to install, though I can understand how a fleet would be more efficient with Budds. For me, an extra 15 minutes isn't a big deal. That time would add up for a fleet.
These two pamphlets provides torque information and tightening patterns:
Webb Torque Specifications
Wheel and Tire Specifications
Dayton tire installation video, courtesy of PDBreske:
New tire installation on Dayton wheels
Anyone have anything to add?
Old 04-06-2015, 09:34 AM   #2
Engine: 190hp 5.9 Cummins
Great post.
Thanks Man.
Old 04-06-2015, 11:48 AM   #3
Chassis: International 1753
Engine: 6.9 International
All good points there. I run Daytons as well, and once you get the knack to aligning them, they really are simple to do.
One problem though, and I hope you can change it in your post, is that nut torque, especially with Dayton's, is subjective to the size of the threads used. 200-260 is for 3/4-10 threads. The studs on mine are 5/8-11, which requires way less torque(ask me how I found that out ). Anyways here is a good page that lists nut torque and other interesting wheel tidbits. http://www.firsttruck.ca/wiki/Wheels...-And-Specs.pdf
I'd think if a moderator could make this a sticky, that'd be a great idea.
Old 04-06-2015, 12:01 PM   #4
Huh.. I'll be damned... I didn't know they came in 5/8-11. I will amend that information if a moderator can unlock the post so I can edit it.
Old 04-06-2015, 01:13 PM   #5
Coachwork: ward
Chassis: international
Engine: dt360a
edit away!
Old 04-06-2015, 01:24 PM   #6
Originally Posted by claydbal View Post
edit away!
I was hoping to get edit abilities on post #1. Possible?
Old 04-06-2015, 03:22 PM   #7
You have laid out all of the main pros and cons for both types of wheels.
I would add one other pro for the Budd wheels.
If you have a bus that the top speed is lower than you would like, you can go to larger wheels with Budd wheels but you can't with Dayton wheels.
On more than a couple of buses I swapped the 22.5" wheels for 24.5" wheels. I gained about 5 MPH at the top end and it didn't change how well the buses climbed hills. On another bus that was really pokey on the hills I swapped the 24.5" wheels for 22.5" wheels and got a little better gradability.
Of course when you do that you need to make sure the weight rating of the tire is sufficient to carry the load whether you are going up or down in tire size.
Old 04-06-2015, 03:25 PM   #8
Very good addition! There is still a bit of wiggle room for Daytons since the tire size goes up to 12r22.5 for 22.5" rims, but you certainly can't jump all the way up to 24.5" wheels.
Old 04-06-2015, 05:47 PM   #9
Engine: TE 444
Rated Cap: 12
If you get a really new bus, you might run into hub piloted bud type wheels, they have the lug nuts with built in washers, not the standard tapered lug nuts
Kubla is online now   Reply With Quote
Old 04-07-2015, 06:20 AM   #10
Coachwork: ward
Engine: dt360a
oops, try again!
