Old 07-27-2012, 05:10 PM   #1
Which Airbag/airspring kit 1991 Minibird
I am at the point where I think I need to consider some suspension improvements. My 1991 Bluebird Minibird Chevy P30 Chassis with 6.2 diesel engine leans to the drivers side even when empty. Accordingly I have been looking at airbag spring lifts. My issue is that when I go searching for them online I find that depending on who you ask that there are several different part numbers stated as being correct for the make model year I have (talking about Firestone kits as they seem to be the standard). Has anyone actually installed air bags on a bus like mine and if so which kit number did you use.
1001 Chevy P30 Blue Bird Handy Bus
oilitright is offline   Reply With Quote
Old 07-27-2012, 05:45 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Which Airbag/airspring kit 1991 Minibird
You would use the one for a 1991 Chevrolet Motorhome P30 Class A
http://www.jcwhitney.com/rv-camper/a...1299j8s18.jcwx just fill in the blanks with the description above. ($289.51 for 1 set). These things made a huge difference in how the Class C rode, drove & handled. They were easy to install as well.
Fulltime since 2006
Old 08-07-2012, 08:29 PM   #3
Year: 85
Coachwork: Ward
Chassis: G.M.C. 6000 series
Engine: 366 G.M.
Rated Cap: 60
I don't even concider using steel springs on anything built in my shop. Air bags are just to easy to install.
Russell is offline   Reply With Quote
Old 08-19-2012, 09:44 AM   #4
Coachwork: Ward Genesis
Engine: DT466/MT643
If it leaans, it sounds like you have a broken spring. Rather than try to Band-Aid it with airbags...why not replace the bad springs with new ones?
Jarlaxle
Skiddy- 1991 MVP CostelloCrew Skoolie Conversion Projects 26 04-17-2016 12:25 PM
1991 International GreyEagle Classifieds | Buy, Sell, Swap 0 05-27-2011 06:56 PM
Selling my 1999 Bluebird Minibird Hearse Driver Classifieds | Buy, Sell, Swap 1 02-28-2011 03:43 PM
'82 GMC Minibird. What is the cylinder tank bolted to f rlloyd20 Short-Bus Conversion Projects 1 06-08-2008 12:11 AM
Which Airbag/airspring kit 1991 Minibird oilitright Skoolie Conversion Projects 1 12-31-1969 07:00 PM
