Old 12-09-2008, 04:48 PM   #21
Re: Which bus/motor would you get if you did it over?
looking at the pictures, it appears to be an inline 6 cyl detroit 6/71 or also known as 238hp 2 stroke, that has been adapted to run laying on its side, mostly oil pan/sump and return system mods. Detroit Diesel also used to modify the V6&8 2 cycle engines for use in the pusher transit busses with V drives to lay on their left side so thgat the heads and valve train could be serviced.
Old 12-09-2008, 05:06 PM   #22
Elliot Naess's Avatar
Engine: 5,9 Cummins
Originally Posted by paul iossi
looking at the pictures, it appears to be an inline 6 cyl detroit 6/71 or also known as 238hp 2 stroke, that has been adapted to run laying on its side, mostly oil pan/sump and return system mods. Detroit Diesel also used to modify the V6&8 2 cycle engines for use in the pusher transit busses with V drives to lay on their left side so that the heads and valve train could be serviced.
Once in a while, I ponder what it might take to convert a common modern engine. I agree, it shouldn't take a whole lot more than oil pan & pickup, and drainback. The drainback might be the difficult part, as I fear the valve guides would suck oil if they were submerged in a pool of it. The mounting should be straight forward crossmembers and brackets made from half inch steel plate. And the SAE bell housing patterns are circular, so the tranny would never know the difference. No more dog house! Yet the radiator could remain up front for best air flow -- the best of both worlds!
Elliot
Old 12-09-2008, 05:35 PM   #23
I think that modern engines are to tall and would be too wide to fit between the frame rails, 33" standard width, but I still havent seen the rulebook that says that you can't build a custom frame. so it becomes an issue of "you pays your money and you take your chances" kind of like a 23 inch roof lift with a monster monobrow.
Old 12-09-2008, 06:21 PM   #24
Engine: 5,9 Cummins
Yieehah -- that means I'm in like flint!
We have a 1985 Caterpillar 3406 with a 13-speed sitting in the back of the yard where I used to work. The Old Man was keeping it for sentimental reasons -- his first brand new truck -- but I think he outgrew that.
Oh... the brainstorms!
Elliot
Old 12-09-2008, 08:20 PM   #25
Joe Monstermaker's Avatar
The 3406 Cat/13-speed would be absolutely awesome, probably the finest drivetrain you could ask for. And it would haul that big crate like it was nothing!
Joe Monstermaker is offline   Reply With Quote
Old 12-09-2008, 10:51 PM   #26
Engine: 5,9 Cummins
ZZZZAP Back to reality... must not let stupid crazy ideas rule my entire life... must resist...
_________________
Captain of the "Land Yacht"
Elliot
Old 12-10-2008, 10:21 AM   #27
AWSOME,
a 400HP+ 3406 with a 13 speed roadranger in Millicent, 100mph uphill and down fully loaded, yup AWSOME by any standards.
then reality kicks in, would believe 70 mph loaded and 9 mpg, just another 15 minuite project, and you would only need to extend the doghouse about 6 inches rearword and 8 inches taller, just minor modifications for a fabricating master like you.
Old 01-18-2009, 12:02 PM   #28
Engine: 5,9 Cummins
Hey, guys.... Let's clear something up, just so nobody goes out and makes a fool of himself.
A Cat 3406 is a 14-plus liter engine and it measures on the order of twice the size of our bus engines. Installing such a beast in a bus... would fall in the category of putting a car engine in a motorcycle. Been done, but definitely not a beginner's project.
Elliot
Old 01-20-2009, 09:04 AM   #29
Coachwork: genesis
Chassis: international harvester
I was researching engines before buying our bus, & the good things I read about the DT466 made me decide that was the best choice, so far I haven't been sorry about my choice, for one thing it's wet sleeve!!!!!
dieselman69 is offline   Reply With Quote
Old 01-20-2009, 09:16 AM   #30
and just to add fuel to the fire a 3406 is one of cat's smaller engines, it's available as a v8, 3408 or V12, 3412 in industrial versions.
What Motor TheHobbits Mechanical and Drivetrains 12 10-27-2014 01:37 PM
motor swap autoqual Ford Drivetrain 1 08-28-2014 05:21 PM
NEED HELP with Gas Motor! AHHHHHH... timbuk Mechanical and Drivetrains 6 01-23-2010 10:39 AM
I use excessive motor oil. ParadigmCrime Everything Else | General Skoolie Discussions 16 08-13-2006 07:28 PM
Motor and trans info on a 1979 ford gas motor auto trans highvoltage21733 Conversion General Discussions 3 10-28-2005 09:31 AM
