Old 01-20-2009, 11:30 AM   #31
Elliot Naess's Avatar
Engine: 5,9 Cummins
Re: Which bus/motor would you get if you did it over?
Originally Posted by paul iossi
and just to add fuel to the fire a 3406 is one of cat's smaller engines, it's available as a v8, 3408 or V12, 3412 in industrial versions.
When I worked at Werner Enterprises (trucking) in the mid 1980s, they built a show truck with a 3412. They bought a Peterbilt glider kit (new truck without engine and rear suspension), moved the cab back a foot, lengthened the hood a foot. 750 HP and torque like a freight train. The stuff that money can do!
Elliot
Old 01-20-2009, 01:01 PM   #32
20 some years later the 3412 is available@ 900+ hp
why not try a 3508, 1600 hp@1800 rpm, transmisions and clutches might be a problem but i'm sure a generator and wheel motors would work.
Old 03-03-2009, 11:13 AM   #33
Year: 1980
Coachwork: Gillig 1980, 2003 Thomas E-350 shorty
Chassis: 636/E350
Engine: Cat 3208 NA/7.3
Well, The long wait is over. I picked up my second Gillig this past weekend, a 1975 636, rear engine CAT 3208 WITH A ROADRANGER RT-610 10 SPEED!!!!! Since it's a pusher, the shift pattern is reversed:
5/10 3/8 1/6
4/9 2/7 R
So far I've only used 4 speeds, 2-4-7-9
The bus is in excellent shape, nice gloss white paint, green and orange-yellow stripe decals on the sides, tinted windows. Based on the grease pen markings in the engine bay, the engine is a replacement re-man with 40k miles. I only drove it approx 25 miles (from Berkeley thru Oakland on the freeway!), tranny-clutch seem fine. I need to practice shifting, especially down shifting. Too much focus on driving, couldn't look at the tach, and wasn't bringing RPM's up enough.
The bus has basement storage, and a compartment for a spare that will become a generator bay. Previous owner was going to make it a mobile homeless shelter, and built 10 nicely done bunks inside, with a rear living area. For now, we'll take it as is to Burningman, and use it as a place for pre-event co-workers to sleep. This will really help those who leave early and then return for the event.
The bus needs tires before it moves again. I'll have some tube-type 10-22 (yes, 22!) wheels available in a month or so in the Oakland area, if anyone needs them. I'm going to put some 11R24.5 wheels/tires on it.
If it isn't grown, it has to be mined
http://weathersticker.wunderground.c...Winnemucca.gif
elkoskoolie is offline   Reply With Quote
Old 03-03-2009, 12:11 PM   #34
Engine: 5,9 Cummins
Congrats! What a find!
I remember looking at a similar bus, but it was too dilapidated to buy. I specially remember studying the shift pattern and linkage, and I concluded that it could be changed to a normal pattern by adding a bell crank to the linkage. Of course, nobody but I would need to do that -- creature of habit that I am.
See you on the Playa! I'll be in Camp Apokiliptika, probably on A Street at about 3:10.
Elliot
Old 03-03-2009, 01:27 PM   #35
Engine: 5,9 Cummins
I've never had a 3208. I put a question mark by its reliability based on what I have read -- mostly here on this very forum a couple of years ago, and also about the Wanderlodges, as I mentioned. If what I remember from that is faulty, then I'm delighted!
Elliot
Old 03-03-2009, 02:17 PM   #36
Year: 1980
Chassis: 636/E350
It'll be awhile before we (if ever) put a lot of miles on the CAT, and with relatively low miles now, it will last us a long time.
Elliot (or others), if you're interested in a Gillig w/ 10 speed, there's a '68 on Craigslist in Oroville CA. I looked at it a month or 2 ago. It needs tires and some work: minor electrical and has a surging idle issue. It has a Cummins 220 mid-engine with an added turbo, Jakes and a Roadranger RT-910 10 speed. He's asking $3300, but I thought If I was going to get it I'd offer $1000. Not sure what it's really worth.
Seeing how my wife is the project manager for Theme Camp Placement, I will advise that there is no way to predict where any camp will be located at Burningman. I'll stop by Apokiliptika and look you up! When we know our location (somewhere in Center Camp), I'll put up a post; both Gilligs will be in our camp this year.
Old 03-03-2009, 05:08 PM   #37
Engine: 5,9 Cummins
Splendid! Please tell your wife that we very much appreciate all her work!
I had my own Theme Camp in 2007 and was very pleased with the Placement process.
Apokiliptika has been in the same area for several years. A couple of years ago, it created Terminal Village (City) with Booby Bar and several other camps. Of course we will set up wherever we are assigned to. But we are hoping to be in the same place as previously.
I believe we have ourselves a case of Thread Drift. Is there a Burning Man 2009 thread yet? I'll take a look.
Elliot
What Motor TheHobbits Mechanical and Drivetrains 12 10-27-2014 01:37 PM
motor swap autoqual Ford Drivetrain 1 08-28-2014 05:21 PM
NEED HELP with Gas Motor! AHHHHHH... timbuk Mechanical and Drivetrains 6 01-23-2010 10:39 AM
I use excessive motor oil. ParadigmCrime Everything Else | General Skoolie Discussions 16 08-13-2006 07:28 PM
Motor and trans info on a 1979 ford gas motor auto trans highvoltage21733 Conversion General Discussions 3 10-28-2005 09:31 AM
