Old 02-22-2009, 04:01 PM   #11
Elliot Naess's Avatar
Engine: 5,9 Cummins
Re: Which engine?
I'm pretty sure... the reason the International DT466 was not mentioned with the Cummins engines above, was that the original poster did not have a DT466 on his list of available choices.
From what I have read, the DT466 is pretty much King Of The Hill, and it would be right up there with the C-cummins in our ranking.
Three or four years ago, when I told my Shop Manager at the trucking company that I was in the market for a bus, he had basically one piece of advice: Get a DT466.
Some of us have indeed brainstormed about "full size" engines, like 60-series Detroit and 3406 Caterpillar. Trouble is, they are huge. And also not cheap, even with 300.000 miles. (That's just two to three years running cross country!)
I'll see if I can remember to measure the big engines at work, come April, maybe.
Elliot
Old 02-22-2009, 11:00 PM   #12
Re: Which engine?
I worked for EDART Nationalease for years and had the advantage of being able to pick the brains of the factory reps. I told him what I had in my head so one day I was shown a little toy.
It was a mid/late 90's 4900 international with a series 60 and a super ten behind it.
Not sure of the year of the engine, but it did have a full ECM set up.
It was not as shoehorned looking as I thought it would have been.
The fellow who put that creature together said it really only needed 4 gears in it as he laughed.
Though it was not proven on a dyno, it was "well over 500 HP" according to him.
This was likely, since we could order that engine at the time at pretty close to that HP number and the shop had tampered with it.
I would love to have a bus with that setup.
250,000 was the cutoff for the insurance company when they got wrecked.
If they had more than that on the driveline, the adjuster would take a lowball offer on the truck if it was a total loss.
I think the guys could buy a wrecked tractor for about 5k if they were pretty well ruined.
(Which is not cheap, I will grant you that...but it would make a VERY nice hill climber in a skoolie and if they were pulling 6.8MPG in a TT, imagine what a bus would deliver for mileage.)
caseythenose is offline   Reply With Quote
Old 02-27-2009, 08:41 PM   #13
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: Which engine?
500HP for a DD 60 is actually low...even the Freightliner Centurys that the low-end OTR companies run (CR England, Swift, Hunt) have that or more. England has run 450-500HP 60's for 10 years.
The 8.2 is a turd?
I went and looked at a truck with that exact engine in it recently.
A friend was buying it to do a certain job and then he was pretty much done with the vehicle.
It was thousands less than anything else out there.
Exactly--just like a neon-pink Yugo with green polka dots & a blown head gasket will be cheap. The 8.2 Detroit is the neon-pink Yugo of the MDT diesel world. The 8.2 is one of three MDT diesels (the others are the 504 and 555 Cummins V8's which are a 70MPH head-on crash of two loaded tri-axle vacuum trucks) I would advise against ever owning under any circumstances, even if they are FREE. I'd rather have a 350 Olds...at least I can swap a 455 into the car & get some use out of the block when that blows up.
Jarlaxle
Old 03-01-2009, 11:30 AM   #14
NewSkewlHauler's Avatar
Engine: 8.2L Detroit N/A, Allison
Re: Which engine?
I'm looking for a Skoolie to convert into a hay/horse hauler as well as carry the wife and five kids across Kansas...and other areas. We haven't set a budget and have only begun looking, but I'm loving all the discussion and tips about motors, brake systems, etc. One motor that I've run across that hasn't been mentioned in this thread has been Cat diesel motors...any opinions out there on those?
More specifically, we're looking for a bus that we can all ride in "comfortably," camp in, and pull a trailer of hay or horses. We have to travel from far western Kansas to Kansas City every month. We are thinking of chopping the back end to allow for a gooseneck hitch for our trailer. If anyone has any opinions, suggestions or advise on a project of this nature, we'd really appreciate it. Thanks!
Ben.
NewSkewlHauler is offline   Reply With Quote
Old 03-01-2009, 03:18 PM   #15
Engine: 5,9 Cummins
Re: Which engine?
However, the Cat 3208 is not known for longevity. And it is costly to overhaul, because it lacks replaceable cylinder liners, such as the IH DT466 has.
Since you are chopping off the rear of the bus for a goose neck hitch, you have eliminated rear engine buses. For a front engine bus, I recommend a "conventional" -- that is, with the engine under a hood. The only reason to buy a flat-nose, with the engine under the floor next to the driver, is if you absolutely must maximize interior space. It is terribly difficult to service the engine in a front-engine flat-nose (like mine).
Elliot
Old 03-01-2009, 06:22 PM   #16
Engine: 5,9 Cummins
Re: Which engine?
Thanks, Mightybus! I just wish I could get around to finishing Millicent. She's operational, with over 10.000 miles since I bought her, but there is so much left to do.
Say... for a while I was watching Blue Bird Wanderlodges for sale. Most of them had the 3208. Seems about half of them had had the engine overhauled or replaced at alarmingly low miles. Lack of correct maintenance?
An other thing.... I believe there are 3208s out there without turbocharging. Probably best to avoid?
Oh... and maybe you can refresh my memory: On a 3208 that I once looked at, the turbo seemed to be strangely small -- not much bigger than my fist. Perhaps I remember wrong?
Elliot
Old 03-01-2009, 08:20 PM   #17
Re: Which engine?
IIRC, 3208's could be had at about 125 hp natural and up to 350 hp turbo charged in marine trim. very reliable if you stay on top of the maintainence and don't even think about overheating it.
Old 03-01-2009, 08:28 PM   #18
Engine: 5,9 Cummins
Re: Which engine?
Yes, a turbocharger is expensive to replace. Luckily, they rarely fail.
I agree that fewer moving parts is a good thing. I was thinking of the efficiency that a turbo provides -- power and fuel economy.
Well, that little turbo was a bit bigger than my fist, but not nearly the size of the turbo on my Cummins 5.9.
Elliot
Old 03-07-2009, 01:14 PM   #19
Re: Which engine?
There are a couple of "band buses" on e-Bay right now. They have a 9.0L International motor. They are both 1986 models. I thought I read somewhere that these are non-turbo motors and are about as good as the 8.2L Detroit? Can anyone confirm or deny this?
Old 03-13-2009, 02:49 PM   #20
Re: Which engine?
I do not want to get into a pissing contest here, but when you make statements like this...it only makes you sound silly.
Even implying that the two engines were even remotely similar in their durability or design is ludicrous.
DOGMAD members were lucky to get 20,000 miles out of a set of head gaskets on the 350 olds diesel engines. They were such an abortion, they are not even worth mentioning.
The fleet numbers are not that bad on the 8.2.
It is so funny how opinions work and the gossip chain...
The 6.2 GM diesel in the early and mid 90's were FAR more problematic with the injection pumps popping on them all the time. The 6.0 powerstrokes (the early ones) were a nightmare in the ambulances with the van noses. They had to replace so many of those because of the head issues and the injection problems.
It is funny how few people bad mouth them though.
I feel the numbers tell a real story in a fleet. You have a driver who really runs the thing, since he or she does not pay for it. They get used hard in a fleet and run hot/cold, jerked, snapped, revved, cold-load tested...etc.
It is more fair to say that the 8.2 has a very different injector setup than the other motors. It is fair to say they do not last as long a 5.9 or a DTinline block...comparing them to an old Olds 350 is silly. An 8.2 will run a fairly reliable 200k before it becomes a problem under most conditions.
I wonder if the brazilian Ford diesel had been in that list where it would have scored?
I could not find fleet data for those anywhere. none of my customers or contacts ever used them.
Same thing with the 7.3 navistar. Millions of them out there in Ford pickups...pretty good luck with them too...but how are they in the buses?
I know they do not last even close to as long as a 5.9 cummins in a pickup truck. Why do we not see more of them in the older buses?
It would be a good idea to see how many members here run which engine.
What are the real numbers on this site?
Possible to replace engine with larger engine? Alexlorraine01 Conversion General Discussions 4 04-22-2014 05:22 PM
Dog Nose vs. front engine vs. rear engine? dgorila1 Conversion General Discussions 20 12-21-2011 06:40 PM
Rear engine VS Front engine (TC Style) BBTC2K Conversion General Discussions 2 12-02-2009 10:25 PM
What is the best engine to look for? nearhomeless Mechanical and Drivetrains 6 05-25-2009 09:13 PM
Replacing Gas engine with Diesel engine question ? soused moose Conversion General Discussions 7 03-17-2005 08:15 PM
