Originally Posted by bfuller181
can you take a picture of what you're looking at? Sounds like we have the same engine, so now I'm worried I need the whole kit.
Sorry for the delay. Please see what my throttle cable looks like. There are two cable bracket "holes" and only one is populated - the one that is populated is mechanically linked to the gas pedal. The second would be used for an aftermarket throttle control like a cruise module. What I'm not sure of is whether or not factor cruise uses a second throttle cable through the second hole, or if they use the primary throttle cable.
Thoughts? Again this is a Chevy 6.0L gas motor from 2003.
Chris
