Old 03-27-2019, 09:18 AM   #1
weboughtabus's Avatar
Coachwork: Corbeil
Engine: Ford PowerStroke Diesel 6.0
Rated Cap: GVWR 11,500
Add Cruise Control '04 E350
I've seen a few threads recently about people adding cruise control to their buses. I tried Googling the procedure for an '04 E350 6.0, but I'm getting some conflicting info. Some people are saying all you have to do is swap out the steering wheel for one that had the necessary controls and other people are saying it involves a whole bunch of additional parts and servos and an ECM reprogram. Does anyone have any experience with this?
Thanks in advance!
charlotte_thebus on Instagram
weboughtabus is offline   Reply With Quote
Old 03-27-2019, 11:21 AM   #2
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 195HP variant
Rated Cap: 72 pax 29500 GVWR
I don’t have personal experience with that model but on most vehicles there is either an actual mechanism/motor that opens the throttle when cruise is activated or it’s done through a drive by wire setup through the existing throttle design. The ECM would also most likely require some programming to allow for it considering the vehicle was built without it.
WARGEAR is offline   Reply With Quote
Old 03-27-2019, 02:00 PM   #3
Year: 2006
Coachwork: Collins
Chassis: Chevrolet Express 3500
Engine: Duramax
It seems to depend on exactly how your chassis was built. I recently saw another skoolie say their 6.0 Ford just needed the steering wheel and clock spring swapped to enable it. On the 7.3 it sometimes required a bit of wiring, but nothing too bad. If you can find a good source for it, you may find it less work to just swap the whole steering column with all the electronics at the same time. I did this in my Chevrolet chassis because it also upgraded me to a tilt column.
dazdconfsd is offline   Reply With Quote
Old 04-09-2019, 12:18 AM   #4
I recently installed cruise control on my 2002 Chevrolet express cutaway short bus. All this required was replacing the factory turn signal switch with one that had the cruise controls built into it (I got it from Rock Auto.com for $60) there is no visual indications on the dash but it works perfectly. Do not assume that just because the CC controls are not physically there that the bus (ECM) is not capable. This may be different with Ford's though. I was not sure mine was going to work but I figured it was only $60 if it doesn't work I'll send it back and get a refund.
Ac76 is offline   Reply With Quote
Old 04-09-2019, 09:30 AM   #5
Coachwork: Corbeil
Thank you. This does comport with some of what I was seeing online. The difference being that I would have to replace the entire steering wheel and clock spring as opposed to just the stalk. I'm hoping that's all it takes. I may have to hit a local junk yard and see how much they'd ding me for a steering wheel and various other bits and bobs I want to replace in my dash area.
Old 04-09-2019, 01:59 PM   #6
farok's Avatar
Engine: 6.0L Gasser
Is there a way to see if the rest of the cruise control parts are there? I have a similar setup - a 2003 Chevy cutaway - but it does not have an electric throttle, and I don't see any extra cables to pull the throttle open (which you would expect on a cruise control-equipped install). I can try the adapter, but I don't have high hopes in that case. Not sure I want to spend $60 that will likely be throw-away if the aftermarket cruise kits come with the part anyway.
Chris
My build thread: http://www.skoolie.net/forums/f27/fi...ild-25804.html
farok is offline   Reply With Quote
Old 04-09-2019, 04:50 PM   #7
Year: 2006
Coachwork: Collins
Engine: Duramax
Chris
From what I know, the lever alone will not work for you since you do not have drive by wire. When I had my 2003 I found this kit that appears to offer all the parts in one package
https://www.thecruisecontrolstore.co...-with-v6-only/
Old 04-09-2019, 08:46 PM   #8
farok's Avatar
Engine: 6.0L Gasser
Great info - thanks so much!! I found other kits, but they don't seem to use an OEM switch like this kit, and are comparable in price.
Chris
Old 05-25-2019, 08:14 PM   #9
bfuller181's Avatar
Chassis: Chevy Express 3500
Rated Cap: 27
what's the difference between the $60 replacement turn signal lever and the $340 cruise control kit?
I've got a 2005 Chevy Express van short bus and I'd really like to add cruise before my big summer trip.
bfuller181 is offline   Reply With Quote
Old 05-25-2019, 10:53 PM   #10
My 2002 Chevy cutaway was basically setup for cruise control with the exception of the lever. The kit is for buses that do not have the option pre-installed (minus the lever with the controls built in). The easiest way to determine if the replacement lever alone will probably work is to trace the wiring from the existing turn signal lever. If memory serves me correct there will be two wires black and green, I think, that pigtail off of the main connector (on the turn signal lever's side) that lead to a smaller two pin connector. In my bus that second connector was located in a plastic holder, since it was unused, above the steering column in a cramped spot. While having this connector may not guarantee that changing the lever alone will work, NOT having this connector basically guarantees you will need more than the turn signal level with built in cruise control (I.E. the whole kit). I took a shot in the dark hoping it would work and luckily for me it did, and it has been worth it.
My 2007 Silverado was apparently sold without the "Driver Information Center" option. But after ordering the button panel all I had to do was plug the panel in and it worked like a charm. In my limited experience Chevy's philosophy seems to be include everything and if the vehicle is not sold with the option just don't install the button panel/switches/levers. Although that may be too much of a generalization to be fully reliable.
