And to find any air problems
Make sure the engine will run. Remove the air compressor discharge air line. Start the engine. Check for any air pressure. If no air, bus can be moved by connecting a portable electric or gas powered compressor to the air line removed. A large bottle of nitrogen with a 100psi regulator will fill the bus tanks OK too. Some times the air problem is as simple as the air compressor governor is broken. The governor is about $50 rebuilt or $25 at a salvage place or rebuild shop. It only needs to have a few bolts r&r to change the governor. Bad governor = no air. Frank
