Old 08-25-2011, 10:14 PM   #1
Buses that don't like to shift out of park?
So it looks like I've come across this twice already with vehicles I'm looking at buying (one a ford E350 and one an E450) both 7.3L engines not sure about the trannys though.
Symptom: Bus will not shift out of park while the bus is on.
Solution: Turn bus off. Foot on Brake. Shift into Neutral. Start bus. Shift into gear
Any idea what causes this?
I've heard some rumors but nothing definitive from someone who's seen and resolved this issue before. One person thought a bad flywheel could be at fault. Another believes that there may have been some sort of Ford TSB that mentioned a wiring harness needing to be replaced (and that it actually wasn't the physical Interlock/BOO relay that tells when you're depressing the brake pedal) I couldn't find any info on that though.
I'd like to figure out how expensive this could be to troubleshoot and fix before putting an offer in.
Thanks.
wirelessguyNY is offline   Reply With Quote
Old 08-26-2011, 02:25 PM   #2
Stuff's Avatar
Re: Buses that don't like to shift out of park?
well if its a newer style you have to hit the brake to take out of park and all i can think is the ignition is worn and you cant get that lever to shift to work when running or something.
Old 08-26-2011, 03:35 PM   #3
freakn's Avatar
Is that when bus is running? does it do it when just the key is with engine off? Sounds like an interlock problem. What year of bus are you working on?
Living the dream in the Kootenays
freakn is offline   Reply With Quote
Old 08-26-2011, 03:52 PM   #4
freakn's Avatar
The brake interlock does not function until the key is on. Check fuse #1 (15 amp)
Ever park in an RV park? Any problems w/homebrew RV's? nearhomeless Conversion General Discussions 23 06-09-2016 05:57 PM
Allison shift point Coalforge Everything Else | General Skoolie Discussions 3 02-14-2007 08:17 PM
Need auto trans shift tower and cable frank-id Classifieds | Buy, Sell, Swap 5 06-30-2006 01:11 AM
I need a floor mounted shift tower frank-id Classifieds | Buy, Sell, Swap 1 06-13-2006 04:41 PM
transmission wont shift right glock17 Skoolie Conversion Projects 3 12-13-2004 10:18 PM
