Old 06-02-2019, 03:41 PM   #41
There's no concern with the coolant level. If you added antifreeze and haven't run the engine, the coolant hasn't gotten past the non opened thermostat to mix with the coolant in the engine. After filing with coolant, rinse off any residual coolant on the outside so you can better determine where the leaks is coming from.
Old 06-02-2019, 06:58 PM   #42
Originally Posted by firebuild View Post
Yes, I have a leak for sure, though it's slow. I can't find it and no mechanic near me can take a look for a couple of weeks, so I have to bandaid the situation by making sure I'm topped off in the meantime.
Just wondering if the leak is at the block heater you got installed?
Might be worth checking and tightening in place.
At least then that can be eliminated as the source of the leak.
Old 06-02-2019, 09:04 PM   #43
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
Interesting! I will check that out!
firebuild is offline   Reply With Quote
