Old 05-24-2010, 11:20 PM   #1
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Engine RPMs
After getting the bus out on the highway with the new tachometer installed I was able to figure out the cruising RPMs. At 100 km/h (as per GPS, speedo is still broken) the engine is turning 3500 rpms. Anyone know what the optimum cruising rpms would be for the Ford 370's? I have found that first gear is pretty much useless and the second through fourth seem to be quite close in ratio, but the jump from fourth gear to fifth is quite wide. If I shift at 4000 rpm from fourth to fifth gear I end up lugging along at 2500 rpm. Also, any idea what the redline is on this engine? Can I spin it faster than 4000 rpm without blowing it up? It sure seems like it is screaming at that speed.
Old 05-24-2010, 11:39 PM   #2
crazycal's Avatar
Re: Engine RPMs
Man, that's screaming. I can't imagine your fuel economy is that great at 3500rpm. I bet you pick up a couple of mpg if you dropped the rpm's by a thousand.
I'm hungry!
You Gotta Let Me Fly
Old 05-25-2010, 12:21 AM   #3
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Re: Engine RPMs
Originally Posted by crazycal
...Man, that's screaming. I can't imagine your fuel economy is that great at 3500rpm. I bet you pick up a couple of mpg if you dropped the rpm's by a thousand.
I figure I get about 6 mpg or so...haven't had it long enough to get an accurate estimate. Also, it is on propane so the tank is never filled to exactly the same level from one fillup to the next due to many variables.
Old 09-22-2010, 03:40 AM   #4
Chassis: B600
Engine: Ford 370
Rated Cap: 16
Re: Engine RPMs
I wouldn't turn that motor much over about 2000-3000 rpm. That is a long stroke small bore motor, they don't like to spin fast.
Iceman_biker is offline   Reply With Quote
Dog Nose vs. front engine vs. rear engine? dgorila1 Conversion General Discussions 20 12-21-2011 06:40 PM
High RPMs? Accordion Mechanical and Drivetrains 17 10-09-2011 01:34 PM
1973 Gillig Problems--Low RPMS and Will not accelerate furthurNbeyond Conversion Tutorials and How-to's 4 01-22-2010 01:02 PM
Rear engine VS Front engine (TC Style) BBTC2K Conversion General Discussions 2 12-02-2009 10:25 PM
Replacing Gas engine with Diesel engine question ? soused moose Conversion General Discussions 7 03-17-2005 08:15 PM
