Old 01-13-2019, 11:09 AM   #121
a pedal to the floor on a diesel is going to allow for more fuel to go into the cylnder.. since the air isnt regulated by the pedal, the fuel is completely, so floored pedal will allow for larger shots.. seems like it might help clear air out of the lines quicker..
Not when it isn't running though?
Old 01-13-2019, 11:21 AM   #122
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
I didn't realize this was a different video - good info.
firebuild is offline   Reply With Quote
Old 01-13-2019, 11:23 AM   #123
Ronnie's Avatar
Engine: 345 international V-8
Yes even when not running
Old 01-13-2019, 11:35 AM   #124
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
so you are supposed to switch to second tank before you run out and shut the engine down on the first tank..
Hey I just noticed that part about shutting the engine down on the first tank. What do you mean by that? Sorry if it's a dumb question.
Old 01-13-2019, 05:36 PM   #125
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
Originally Posted by firebuild View Post
Now I'm REALLY confused. That doesn't look remotely like my engine, so I can't even figure out where physically he is doing this.
I get it now! Today was the first time I opened the doghouse.... and that's where the resemblance to this video is. You have to remember I am a 100% novice.
Old 01-13-2019, 05:40 PM   #126
Ah, I was gonna ask if you'd pulled off the doghouse!!!!!!!!
Old 01-13-2019, 06:18 PM   #127
This may sound like a dumb question but a lot of the Ford vehicles with the 6.9/7.3L diesel engines had a manual pump on the fuel filter that helped with priming--does your Ford have the hand pump on the fuel filter?
As far as priming and not starting because it is cold, if you loosen (crack open) one of the injector lines and fuel comes out while cranking then you are primed enough to get started.
Old 01-13-2019, 06:39 PM   #128
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
No, it just has a tiny little valve that looks like the pump valve on a basketball.
