Old 09-30-2017, 11:37 AM   #1
stone21's Avatar
Year: 2005
Coachwork: blue bird
Chassis: handy
Engine: e450 6.0
hole to hades?
there's a hole in the floor seemingly for access to the diesel fuel tank from above...don't think it is meant to sweep dirt into ...what repair might be needed to require access to the tank from above?...and is it important to keep when i replace the flooring?
stone21 is offline   Reply With Quote
Old 09-30-2017, 11:54 AM   #2
Year: 93
Engine: 7.3 idi
Mine had one i left it accessible. I'd guess it'd be for a fuel pump or such.
Greatestrr is offline   Reply With Quote
Old 09-30-2017, 12:11 PM   #3
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
Fuel sending unit is down there. If it goes out, no fuel gauge.
wunderhut is offline   Reply With Quote
Old 09-30-2017, 01:56 PM   #4
As above. Access to sending unit. Do NOT hard cover it or you will have to drop the tank to get to the sender. They don't last forever.
I made a new cover for mine that is now located inside the storage under a fold out sleeper.
Old 09-30-2017, 02:13 PM   #5
Chassis: Saf-T-Liner MVP ER
.... and don't buy a Ford Wndstar.
They forgot to put in an access panel for the fuel pump, and the tank has to come out to replace it ... and it WILL need replacing.
Don't ask me how I know!
Steve Bracken
Build Thread
Old 09-30-2017, 02:31 PM   #6
A 4-1/2" grinder and thin kerf cut off wheel will provide access right nicely.
Old 09-30-2017, 03:13 PM   #7
Cutting through thin steel that has a plastic gas-tank slung up against it, didn't appeal
Steve Bracken
Build Thread
Old 09-30-2017, 07:56 PM   #8
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I covered mine & redesigned so I can drop the tank if need be.
Old 09-30-2017, 08:59 PM   #9
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
I dropped my tank, figured- how hard can it be? SOB had so many locknuts, so many safety plates...my bus was too far from the air and not mobile, so did it all by hand...in the winter..in Chicago. Tore my f#@$%ing bicep, still healing.
Cleaned /painted tank, cleaned sender, verified working. Reassembled sender. Don't work.
Next....
Old 10-01-2017, 05:08 PM   #10
Next....
It does help to have proper & nessary equipment, I use a transmission Jack to lower my tanks .
Old 10-01-2017, 05:20 PM   #11
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
The mechanic had to drop the fuel tank on my 98 Astro to replace the fuel pump. Unfortunately, the idiot did NOT follow installation instructions on the new plug harness. He only twisted the ends together with wire nuts instead of soldering them. Cost me $400 MORE to fix his screw-up.
Old 10-01-2017, 05:34 PM   #12
Traveling
Rated Cap: '00
That is baloney. When I was 20, I had a 1959 FJ40 I had the engine rebuilt, so I thought. They powerwashed it and painted it blue, for $2200. He did that to 10 other customers and we class-actioned him out of biz.
After that I did all my own repairs- my 2002 truck that I bought new has never seen a "pro" shop.
