Old 03-24-2019, 08:07 AM   #1
Chassis: Ford Blue Bbird
How to grease drive shaft 88 Blue bird
I just bought an 88 bluebird drove it 150 miles home, all went well but when I was looking it over I found that where the drive shafts link up are bone dry. I am going to grease them before moving it anywhere but want to make sure I get the grease everywhere it needs to go. Can anyone point me to a YouTube video that will show me, or maybe a series of pictures?
Ladynic73 is offline   Reply With Quote
Old 03-24-2019, 10:18 AM   #2
Chassis: IH
If there is a grease fitting, you should be able to use a common grease gun to fill them.
Old 03-27-2019, 08:13 AM   #3
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
If the driveshaft and u joints are serviceable, you will see grease nipples/zerk fittings either in the cross shaped portion or the end cup of the u joints and a fitting near any splined sliding shafts writhing the driveshaft. Pump them with grease until the old starts coming out and you see some new and wipe clean.
WARGEAR is offline   Reply With Quote
