Old 11-20-2011, 04:43 PM   #1
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: How to release parking brake B700?
Uh-oh. You have the dreaded Lucas-Girling hydraulic brakes. That uses sspring brakes (like an air system) that are released by pressure from the PS pump. They won't release with the engine off, though there MUST be a way to disengage them for towing.
Short answer: I have no idea. I suggest calling a truck shop that knows these brakes or a heavy-haul towing company.
Jarlaxle
Old 05-09-2015, 07:55 AM   #2
Are these the electric over hydraulic? Click image for larger version
ID:	6871. Click image for larger version
ID:	6872. Gurling the same thing?
luckychucky is offline   Reply With Quote
Old 05-09-2015, 09:05 AM   #3
Engine: 190hp 5.9 Cummins
Use a wrench and back off the rear brake pots just like air brakes.
It is the only hydraulic brake system that works this way.
Front is not engaged by the parking brake.
Old 01-13-2016, 07:04 PM   #4
Please tell me where the pots are located?
Old 01-13-2016, 07:57 PM   #5
Chassis: B3800 Short bus
The pots are next to each set of wheels under the drive axle (if I'm remembering correctly). They are cylindrical and should be quite obvious.
Something like this:
Old 01-15-2016, 10:51 AM   #6
Thank you!
Old 06-28-2021, 07:34 PM   #7
Engine: 6.6L Ford/New Holland
Rated Cap: 36 Passengers
Hydraulic Parking Brake Removal
I have a 1988 Ford B600/Ward with this hydraulic brake system and I’ve purchased an Allison 1000 to replace the original Allison 545. Other than gaining double overdrive, I will also have a parking pawl as well as a driveshaft parking brake that are included with the transmission. My question is: has anyone in the skoolie world ever considered removing the hydraulic parking brake system in lieu of a mechanical parking brake system? And/or would it be more trouble than it’s worth?
Thanks in advance...
Diehard is offline   Reply With Quote
Red knob next to the parking brake lever bbeenn88 Conversion General Discussions 9 04-26-2014 06:23 PM
Freedom Parking lornaschinske Everything Else | General Skoolie Discussions 11 05-26-2013 05:09 PM
air brake 101...or how to fix/diagnois a stuck brake issue bansil Conversion General Discussions 16 06-28-2012 02:28 PM
Skoolie Parking near Nashville, TN??? Taillights FaDe On the Road | Travel, Trips, Camp Sites, Tailgates 0 11-28-2007 09:42 PM
Upgraded Forum to latest release. Steve Forum Admin | Account Help | Suggestion Box 0 03-15-2004 03:08 PM
