Old 05-17-2018, 07:07 PM   #1
hydro asst hydrolic brakes
why assist pump energizing when no brakes applied
fallsman is offline   Reply With Quote
Old 08-02-2018, 09:07 PM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
what you have
is called Hydro max hydraulic boost made by bosch/bendix
There are sever places on the internet to read about how the system works and you may find the answer to your question there.
william
Old 08-03-2018, 06:57 AM   #3
Chassis: B3800 Short bus
Fallsman: you didn't provide much context. Is the electric pump always running? Even when the bus is running and also when the key is removed?
The expected behaviour is that the pump is continuously running when the key is turned to "run" and the engine is not running. Also, with the ignition off the pump will run when the brake pedal is pushed.
Old 08-03-2018, 10:25 AM   #4
Have a look at your brake switch where it contacts the pedal mechanism.
It is probably making contact there. You need to adjust it so there is a small gap so that switch makes only when the pedal gets pushed.
That will stop the pump from running endlessly.
Old 08-04-2018, 07:56 AM   #5
golfersmurf57's Avatar
The electric pump comes on if the key is on and there's no flow from the engine driven p/s pump there's a flow switch and relay that control the aux motor. It will run in key on engine off mode as well. You can get testing info on Mitchell heavy duty so your local truck bus shop may be able to print the pages for you. Usually you're out of steering fluid due to leakage or your belt is not turning the pump -loose or not on.
golfersmurf57 is offline   Reply With Quote
