Old 08-11-2017, 10:43 AM   #1
Is anyone familiar with this Overdrive switch?
https://www.fordpartsgiant.com/parts...-relays,,7G550
I have this same doodad on my dash. It fell apart. and Im 800 miles from home. I havent noticed anything detrimental going on but the bulb that is handled by the dash light switch is working. I assume thats for illumination. the yellow diode is unlit so I am assuming the OD is ON. WHich is where I want it for now.
Once I get home in a couple days, I'd like to replace the switch. But for now I want to make sure the OD is functioning.
Zerhackermann is offline   Reply With Quote
Old 08-11-2017, 01:24 PM   #2
roach711's Avatar
Rated Cap: 19
4th gear will be your overdrive. From a dead stop count the shifts. If it gets to 4th your good to go. The "cancel overdrive" switch is used for long hills or when towing.
The Roach Motel
Old 08-12-2017, 07:29 AM   #3
Thanks!
(adding ten characters because the software is stoopit)
