Old 01-22-2019, 03:28 PM   #21
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
Originally Posted by Booyah45828 View Post
Hopefully you got one for a 1.5 inch hole. I believe it's kats #30403.
The heater must go in the rear most passenger side hole. The others won't work because they're cut to use a welch type freeze plug, while the hole you have to use is cut for a cup type plug.
Did you ever check that it didn't have one in it to begin with? I've seen certain times where every engine on the line got a heater. The difference was the ones that ordered it where given the cord to use it.
I got Zerostart 310-0043 Engine Block Heater.
I most definitely do NOT have one.
firebuild is offline   Reply With Quote
