Old 08-27-2014, 10:09 AM   #1
Year: 1983
Coachwork: wayne
Chassis: b600
Engine: 370 ford
motor swap
I have a 1983 ford b600 thinking about a motor swap, it has a 370 with a Allison at545 that same year was offered with a 8.2 lt diesel is it a direct swap will it bolt to the Allison at545? or do I have to upgrade tran to at643 (that may be the wrong # it off the top of my head). any other major mods? not married to the detriot diesel I just stock in that and yr and model. I would like to keep this simple. the schoolie has sentimental value so replacing the bus is out but the misses and I would like to travel and based on hill performance mountains would be sketchy at best. would like to hear what everyone thinks
autoqual is offline   Reply With Quote
Old 08-28-2014, 05:21 PM   #2
frank-id's Avatar
Re: motor swap
To determine if any engine will fit any trans, first count the bolts connecting the engine to the trans. Nearly any engine can be connected to any trans with an adapter. Find a Allison AT545 or call around and determine the bolt count. There are 6 major bell housing adapters and sizes with different number of bolts. The Allison MT 643 is a medium duty trans unlike the AT 545. Frank
366 carb to 427 FI swap!! jaredg GM | Chevrolet Drivetrain 13 02-18-2015 09:01 PM
Had the diff swap done... thrash International | Navistar Drivetrain 15 05-21-2013 10:08 PM
GMC 6.2 swap bapos Mechanical and Drivetrains 23 11-26-2012 12:13 AM
motor swap suggestions for 7.3L IDI NewSkewlHauler International | Navistar Drivetrain 3 04-24-2010 06:07 AM
Motor and trans info on a 1979 ford gas motor auto trans highvoltage21733 Conversion General Discussions 3 10-28-2005 09:31 AM
